Street Strip Transfluid #992117
05/14/11 10:24 AM
05/14/11 10:24 AM
FT Campbell, KY / Clarksville,...
The Cuda Guy Offline OP
Guys wanted to check in before I pull the trigger on some transfluid. What are you guys running?
I have read all kinds of stuff in the past like 10w30 to Type F. But what will be a good fluid for a 493/727, 3500 stall with a lot of strip time. Thanks.
Don
Street/Strip 73 Barracuda
Re: Street Strip Transfluid [Re: The Cuda Guy] #992118
05/14/11 10:31 AM
05/14/11 10:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Cheapo type F... thats what I run in the race car and
thats what I'll run in my street/strip Rampage 518 trans
Re: Street Strip Transfluid [Re: MR_P_BODY] #992119
05/14/11 10:50 AM
05/14/11 10:50 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
x2
using anything else is a total waste of money. withstands 1100 hp in my glide
home of the
Sox and Martin Hemi Duster
Re: Street Strip Transfluid [Re: HEMIFRED] #992120
05/14/11 10:55 AM
05/14/11 10:55 AM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Where is the best place to get the cheap type F?
The cheapest i can find it around here is $3.50 a quart.
Re: Street Strip Transfluid [Re: HEMIDARTS] #992121
05/14/11 11:19 AM
05/14/11 11:19 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
Wally World ..... and I am going to REcheck Tractor Supply for a 5 gallon pail.
Re: Street Strip Transfluid [Re: dOOc] #992122
05/14/11 12:00 PM
05/14/11 12:00 PM
Thanks for the feedback.
Don
Re: Street Strip Transfluid [Re: dOOc] #992123
05/14/11 01:18 PM
05/14/11 01:18 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
i will be checking for a 5 gallon pale myself
Re: Street Strip Transfluid [Re: HEMIFRED] #992124
05/14/11 03:09 PM
05/14/11 03:09 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Re: Street Strip Transfluid [Re: HEMIDARTS] #992125
05/14/11 03:14 PM
05/14/11 03:14 PM
Washington State
lorenr Offline
lorenr  Offline
Washington State
Sorry, but I'd like to understand the reason for the "cheap" type F. I know that nearly all transmission fluid complies with a standard so the brand matters little. But I'm curious.
I know there is Type F, Mercon III to V and maybe VI. There is synthetic such as Mobil I and Transynd for Allison transmissions. I'm pretty sure the synthetics take heat a lot better.
Do you you use Type F because you change it so often?
Re: Street Strip Transfluid [Re: lorenr] #992126
05/14/11 05:00 PM
05/14/11 05:00 PM
sg66mopar Offline
sg66mopar  Offline
We use Type F because it's "stickier". Less slippage in the clutch packs = longer life on the track.
Re: Street Strip Transfluid [Re: lorenr] #992127
05/14/11 05:06 PM
05/14/11 05:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The fluid in my trans has been in there for about
5 years... still works fine... no burnt smell... thats
on a trans brake launch everytime
Re: Street Strip Transfluid [Re: MR_P_BODY] #992128
05/14/11 08:53 PM
05/14/11 08:53 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I was unable to find Type F at wally world by the gallon. I use the cheap Vtech Dexron Mercon. Had good luck with it.
Just tried the hydrastatic trans hydrualic fluid. It was thick and made the converter act lazy. Was told it would lower the stall but the Racepac said otherwise.
Leon
Re: Street Strip Transfluid [Re: sg66mopar] #992129
05/14/11 09:09 PM
05/14/11 09:09 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
been using F for that exact reason as per DIRECT CONNECTION recommendation back in 1967
home of the
Re: Street Strip Transfluid [Re: HEMIFRED] #992130
05/14/11 09:17 PM
05/14/11 09:17 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
been using F for that exact reason as per DIRECT CONNECTION recommendation back in 1867
FIXED .....
DAMN Fred ...I didn't know you were THAT OLD ?
Re: Street Strip Transfluid [Re: dOOc] #992131
05/14/11 09:30 PM
05/14/11 09:30 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
FIXED .....
I can answer "WHERE WERE YOU IN 62" with "at the drags"
home of the
Re: Street Strip Transfluid [Re: HEMIFRED] #992132
05/15/11 02:03 AM
05/15/11 02:03 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Type F in old cars.
MB1 syn for most late models. Dex VI in late model GM's. Lots of heat issues in late model stuff.
I want my fair share
Re: Street Strip Transfluid [Re: sg66mopar] #992133
05/15/11 02:14 AM
05/15/11 02:14 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
B&M trick shift baby
Mopar Performance
Re: Street Strip Transfluid [Re: moparniac] #992134
05/15/11 04:02 AM
05/15/11 04:02 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Back in '71-'72 I worked for Bob & Don Spar (B&M), and the story around the place was that the Trick Shift was Type F repackaged with the B&M logo.
It was cool there: got to work with Kent Fuller, K.S. Pittman, and some other drag racing icons...many stories...
Re: Street Strip Transfluid [Re: topside] #992135
05/15/11 10:46 AM
05/15/11 10:46 AM
PA
moparacer Offline
moparacer  Offline
PA
Have Motorcraft type F in my glide right now.
Have used Dextron 3, Mobil 1 synthetic and hydraulic oil in it with no problems.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
