Street Strip Transfluid
#992117
05/14/11 10:24 AM
05/14/11 10:24 AM
Posts: 376 FT Campbell, KY / Clarksville,...
The Cuda Guy
Guys wanted to check in before I pull the trigger on some transfluid. What are you guys running?
I have read all kinds of stuff in the past like 10w30 to Type F. But what will be a good fluid for a 493/727, 3500 stall with a lot of strip time. Thanks.
Don
Street/Strip 73 Barracuda
Re: Street Strip Transfluid
[Re: HEMIDARTS]
#992125
05/14/11 03:14 PM
05/14/11 03:14 PM
Posts: 29 Washington State
lorenr
Washington State
Sorry, but I'd like to understand the reason for the "cheap" type F. I know that nearly all transmission fluid complies with a standard so the brand matters little. But I'm curious. I know there is Type F, Mercon III to V and maybe VI. There is synthetic such as Mobil I and Transynd for Allison transmissions. I'm pretty sure the synthetics take heat a lot better. Do you you use Type F because you change it so often?
[Re: lorenr]
#992127
05/14/11 05:06 PM
05/14/11 05:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The fluid in my trans has been in there for about 5 years... still works fine... no burnt smell... thats on a trans brake launch everytime
[Re: MR_P_BODY]
#992128
05/14/11 08:53 PM
05/14/11 08:53 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I was unable to find Type F at wally world by the gallon. I use the cheap Vtech Dexron Mercon. Had good luck with it.
Just tried the hydrastatic trans hydrualic fluid. It was thick and made the converter act lazy. Was told it would lower the stall but the Racepac said otherwise.
Leon
[Re: HEMIFRED]
#992130
05/14/11 09:17 PM
05/14/11 09:17 PM
Posts: 30,431 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
We use Type F because it's "stickier". Less slippage in the clutch packs = longer life on the track.
been using F for that exact reason as per DIRECT CONNECTION recommendation back in 1867
FIXED .....
DAMN Fred ...I didn't know you were THAT OLD ?
[Re: HEMIFRED]
#992132
05/15/11 02:03 AM
05/15/11 02:03 AM
Posts: 10,214 Someplace you aren't
SomeCarGuy
Type F in old cars.
MB1 syn for most late models. Dex VI in late model GM's. Lots of heat issues in late model stuff.
I want my fair share
[Re: topside]
#992135
05/15/11 10:46 AM
05/15/11 10:46 AM
Posts: 2,508 PA
moparacer
PA
Have Motorcraft type F in my glide right now.
Have used Dextron 3, Mobil 1 synthetic and hydraulic oil in it with no problems.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
