small block strokers #991927
05/13/11 11:10 PM
05/13/11 11:10 PM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
what are you running for rear gears, tall of tire, and your shift point and trap rpm?, I run 410 now was thinking of a 430 to try
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: small block strokers [Re: Stroker Scamp] #991928
05/13/11 11:22 PM
05/13/11 11:22 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
small block 408 gears 489 tire 33 tall shift at 6,800 trap rpm 7100 trans 727
Re: small block strokers [Re: cbarracuda] #991929
05/13/11 11:38 PM
05/13/11 11:38 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
4.10 gears, and it revs so quick with the drag radials, cause they spin, I haven't had a consistant rpm yet. But 4.10 with a 28" tall tire and I am thinking a little less would be even better. Shifts come up a little quick. I started to get a good hook, and the trans let go, so I will get back to you.
Re: small block strokers [Re: Dragula] #991930
05/13/11 11:42 PM
05/13/11 11:42 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
4.56 in mine,,need to change to a 4.30 next time i put new gears in.
Re: small block strokers [Re: dartman366] #991931
05/13/11 11:47 PM
05/13/11 11:47 PM
PA
moparacer Offline
moparacer  Offline
PA
4.10 gears 28 X 10.5 tires shift at 6500 and cross at 6600 with our 408 small block.
Converter is going to have alot to do with the trap RPM.
Ours flashes to 5200 on launch.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: small block strokers [Re: moparacer] #991932
05/14/11 12:02 AM
05/14/11 12:02 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
416 with 4.88's and 32" tall tire shifting at 7300 and crossing the line about 7200
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: small block strokers [Re: dusturbd340W5] #991933
05/14/11 06:28 AM
05/14/11 06:28 AM
canada,NB
jb15 Offline
jb15  Offline
canada,NB
360 stroked to 408ci-4.88's,32" tire,shifting @7200 and crossing line @7900...
Re: small block strokers [Re: jb15] #991934
05/14/11 07:13 AM
05/14/11 07:13 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
416, 4.88's, 30" tire, shift @ 7K trap in the 1/8th 7100, 1/4 7600
Re: small block strokers [Re: jb15] #991935
05/14/11 08:12 AM
05/14/11 08:12 AM
Q
Quicktree Offline
Quicktree  Offline
Q
if you are crossing at 7900 with a 32" tire I would be checking something. maybe converter?
Re: small block strokers [Re: Quicktree] #991936
05/14/11 10:48 AM
05/14/11 10:48 AM
Kissimmee Fl.
Kissimmee Fl.
I am running the same gear and tire combo and am no where near 7900 at the line
Re: small block strokers [Re: Stroker Scamp] #991937
05/14/11 11:19 AM
05/14/11 11:19 AM
Az
Crizila Offline
Crizila  Offline
Az
408, 4.56 gears. 28" tire. 2400rpm convertor. Shift at 6400. Go through the lights at around 6500. A tad to much gear for my combo-IMO. Going to go to a 29 or 30" tire when my existing tires get completely bald headed. Cam = Hyd. .606/.614 @ 1.6, 246 / 250, 108LSA. 180 suggested cyl press.
Fastest 300
Re: small block strokers [Re: Crizila] #991938
05/14/11 11:36 AM
05/14/11 11:36 AM
412 SB Duster Offline
412 ci
430s with 29x12 hoosiers
shift @ 7000
traps @ 7200
best of 9.96@132.56
Re: small block strokers [Re: 412 SB Duster] #991939
05/14/11 11:41 AM
05/14/11 11:41 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Any chance some of you guys can throw in the cam specs with the RPM info
Re: small block strokers [Re: emarine01] #991940
05/14/11 12:05 PM
05/14/11 12:05 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
414 12:1 with a 266/269 @.050 107 solid roller, starting out with a 4.56 gear and a 29.5" M/T drag radial. Looking for an ~6500 shift point for mainly 1/8th mile but I'm sure the motor will rev to +7K if I need it to. Hopefully it will have enough tire not to need a taller gear for the quarter. If it's too sqirrely off the line I'll be looking to trade out to a 3.91-4.10.
Needless to say I'm really interested in this thread
I agree the vert efficiency will have a lot to do with your trap RPM, I'm starting out with a loose (36-3800 stall) 10" T/A that probably won't be very efficient up top for the 1/4...but probably not worth changing for 1/8 mile week-end action. An 8" 4500 stall (probably most ideal for this motor combo) would flip this little 85" wb car over backwards for sure.
Head flow would be helpful too...mine are stage 2 Shady Dell eddies that flow ~275 at the peak valve lift (.585). This cam is a Mopar IROC cam so it's not a really high lift, but it's a perfect low maintenance, easy-on-parts type grind for a light bracket combo.
WIZE
In Car:
Re: small block strokers [Re: Streetwize] #991941
05/14/11 01:36 PM
05/14/11 01:36 PM
Kalispell Mt.
HotRodDave Online content
HotRodDave  Online Content
Kalispell Mt.
I think a lot of guys are just running too low of gears those little big motors make lots of TQ and based on the shift RPM VS trap RPM you guys are just running out of gear at the top end, I bet most of you would be faster with a tad higher gears. Mabey if you threw out your MPH as well as trap RPM and tire height and gear we would know for sure
Re: small block strokers [Re: HotRodDave] #991942
05/14/11 02:20 PM
05/14/11 02:20 PM
Az
Crizila Offline
Crizila  Offline
Az
I am for sure. Went from a 4.10 to a 4.56 ( there were no choices inbetween for my diff ). I'm am trying to move a very heavy car. The change actually netted me about .004 in my 60 foot times and cost me about 1-2 mph and my 1/4 mile ET improved about 1/2 a tenth best I can figure - really not much change at all. I am buzzing the motor a little higher than I want to though. Needless to say, I was a little disappointed
Fastest 300
Re: small block strokers [Re: Stroker Scamp] #991943
05/14/11 02:35 PM
05/14/11 02:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
405ci, 4.56, 31" tire, 5600 stall. shift at 7700,
trap at 8000
Re: small block strokers [Re: Quicktree] #991944
05/14/11 03:45 PM
05/14/11 03:45 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Jim's Barracuda runs in the 8's!!!
Re: small block strokers [Re: S/ST 3040] #991945
05/14/11 05:08 PM
05/14/11 05:08 PM
canada,NB
jb15 Offline
jb15  Offline
canada,NB
Thanks Vic, if I thought there was a conv. that would run me quicker, I'd buy it.
Jim.
best= 8.92 @150 mph, 1.25 60s,
Re: small block strokers [Re: S/ST 3040] #991946
05/14/11 05:08 PM
05/14/11 05:08 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Ok well that explains a little
