small block strokers
#991927
05/13/11 11:10 PM
05/13/11 11:10 PM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
what are you running for rear gears, tall of tire, and your shift point and trap rpm?, I run 410 now was thinking of a 430 to try
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: small block strokers
[Re: dartman366]
#991931
05/13/11 11:47 PM
05/13/11 11:47 PM
Posts: 2,524 PA
moparacer
PA
4.10 gears 28 X 10.5 tires shift at 6500 and cross at 6600 with our 408 small block.
Converter is going to have alot to do with the trap RPM.
Ours flashes to 5200 on launch.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#991932
05/14/11 12:02 AM
05/14/11 12:02 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
416 with 4.88's and 32" tall tire shifting at 7300 and crossing the line about 7200
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: jb15]
#991935
05/14/11 08:12 AM
05/14/11 08:12 AM
Quicktree
360 stroked to 408ci-4.88's,32" tire,shifting @7200 and crossing line @7900...
if you are crossing at 7900 with a 32" tire I would be checking something. maybe converter?
[Re: Stroker Scamp]
#991937
05/14/11 11:19 AM
05/14/11 11:19 AM
Posts: 7,506 Az
Crizila
Az
408, 4.56 gears. 28" tire. 2400rpm convertor. Shift at 6400. Go through the lights at around 6500. A tad to much gear for my combo-IMO. Going to go to a 29 or 30" tire when my existing tires get completely bald headed. Cam = Hyd. .606/.614 @ 1.6, 246 / 250, 108LSA. 180 suggested cyl press.
Fastest 300
[Re: emarine01]
#991940
05/14/11 12:05 PM
05/14/11 12:05 PM
Posts: 9,888 Weddington, N.C.
Streetwize
Weddington, N.C.
414 12:1 with a 266/269 @.050 107 solid roller, starting out with a 4.56 gear and a 29.5" M/T drag radial. Looking for an ~6500 shift point for mainly 1/8th mile but I'm sure the motor will rev to +7K if I need it to. Hopefully it will have enough tire not to need a taller gear for the quarter. If it's too sqirrely off the line I'll be looking to trade out to a 3.91-4.10. Needless to say I'm really interested in this thread I agree the vert efficiency will have a lot to do with your trap RPM, I'm starting out with a loose (36-3800 stall) 10" T/A that probably won't be very efficient up top for the 1/4...but probably not worth changing for 1/8 mile week-end action. An 8" 4500 stall (probably most ideal for this motor combo) would flip this little 85" wb car over backwards for sure. Head flow would be helpful too...mine are stage 2 Shady Dell eddies that flow ~275 at the peak valve lift (.585). This cam is a Mopar IROC cam so it's not a really high lift, but it's a perfect low maintenance, easy-on-parts type grind for a light bracket combo.
[Re: Quicktree]
#991944
05/14/11 03:45 PM
05/14/11 03:45 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Jim's Barracuda runs in the 8's!!!
[Re: S/ST 3040]
#991945
05/14/11 05:08 PM
05/14/11 05:08 PM
Posts: 214 canada,NB
jb15
canada,NB
Thanks Vic, if I thought there was a conv. that would run me quicker, I'd buy it. Jim. best= 8.92 @150 mph, 1.25 60s,
[Re: S/ST 3040]
#991946
05/14/11 05:08 PM
05/14/11 05:08 PM
Quicktree
Ok well that explains a little
