rebushing throttle bores, what to use
#987347
05/06/11 10:11 PM
05/06/11 10:11 PM
RapidRobert
Planned on drilling out the baseplate bores/pressing in a bushing/ream bushing ID to fit shaft. Sound good? What would you suggest I use/any tips/anything I am missing. Thank you for your time.
Re: rebushing throttle bores, what to use
[Re: jjl]
#987349
05/06/11 10:42 PM
05/06/11 10:42 PM
RapidRobert
Can I buy guide liners commercially esp as I have some valve guides to do also. Mc Masters or goodson or??
[Re: RapidRobert]
#987350
05/06/11 11:14 PM
05/06/11 11:14 PM
Posts: 16,820 Between Houston & Galveston TX
SattyNoCar
Being the cheapskate I am, I just used brass tubing from the local hobby shop. I forget the size, but, I took a bare shaft with me to find the size. Mine was worn enough that I didn't need to drill the base plate. I cut the tubing a little long, and carefully tapped it in with a small hammer and a piece of wood. I cleaned up the (inside) edge with a small rat tail file. Once the 'bushing' was in, I set the base plate on its side and put a few drops of loctite red around the bushing. Its held up just fine in a real everyday driver situation and did away with that annoying whistle.
John
[Re: SattyNoCar]
#987351
05/06/11 11:17 PM
05/06/11 11:17 PM
RapidRobert
I'll prob freeze the bushing/slightly heat the baseplate. I'm worrying if the shaft will b worn unevenly & need attention
[Re: BeEtLeJuIcE !]
#987353
05/07/11 12:44 AM
05/07/11 12:44 AM
RapidRobert
Not sure bro but I want to do em (dual AFB's going on a 451) to b proactive & I want to spend some money plus they're 40 + years old
[Re: RapidRobert]
#987354
05/07/11 12:49 AM
05/07/11 12:49 AM
Posts: 30,429 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
I have never REbushed a base plate ever. Never ran into a carb that I was going to do or use that needed it...... B U T ... I have heard of some that were soooo bad that they caused severe vacuum leaks ...and actually were ... Your point about getting them in STRAIGHT and TRUE should be a concern. I would say take them to a small machine shop locally.
[Re: RapidRobert]
#987356
05/07/11 06:35 PM
05/07/11 06:35 PM
Posts: 25,802 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Reaming the baseplate oversize for bushings requires a reamer with a pilot that's long enough to extend all the way through the baseplate before the flutes make contact. This is the only way to prevent crooked throttle shaft bores.
[Re: John_Kunkel]
#987357
05/07/11 08:58 PM
05/07/11 08:58 PM
RapidRobert
Thank you John & a guy has the right stuff & wants 25 a carb so I might just let him go ahead
[Re: ScottSmith_Harms]
#987361
05/07/11 09:54 PM
05/07/11 09:54 PM
RapidRobert
I have 2 identical 4131S AFB's & for sure dont want to mess one up
