rebushing throttle bores, what to use #987347
05/06/11 10:11 PM
05/06/11 10:11 PM
RapidRobert Offline OP
Planned on drilling out the baseplate bores/pressing in a bushing/ream bushing ID to fit shaft. Sound good? What would you suggest I use/any tips/anything I am missing. Thank you for your time.
Re: rebushing throttle bores, what to use [Re: RapidRobert] #987348
05/06/11 10:38 PM
05/06/11 10:38 PM
utah
jjl Offline
jjl  Offline
utah
I used bronze guide liners to do a tquad,once.Ream,press in,them broach to size.Some auto machine shops use them,they could help.
formally orangemonster
Re: rebushing throttle bores, what to use [Re: jjl] #987349
05/06/11 10:42 PM
05/06/11 10:42 PM
Can I buy guide liners commercially esp as I have some valve guides to do also. Mc Masters or goodson or??
Re: rebushing throttle bores, what to use [Re: RapidRobert] #987350
05/06/11 11:14 PM
05/06/11 11:14 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Being the cheapskate I am, I just used brass tubing from the local hobby shop. I forget the size, but, I took a bare shaft with me to find the size. Mine was worn enough that I didn't need to drill the base plate. I cut the tubing a little long, and carefully tapped it in with a small hammer and a piece of wood. I cleaned up the (inside) edge with a small rat tail file. Once the 'bushing' was in, I set the base plate on its side and put a few drops of loctite red around the bushing.
Its held up just fine in a real everyday driver situation and did away with that annoying whistle.
John
Re: rebushing throttle bores, what to use [Re: SattyNoCar] #987351
05/06/11 11:17 PM
05/06/11 11:17 PM
I'll prob freeze the bushing/slightly heat the baseplate. I'm worrying if the shaft will b worn unevenly & need attention
Re: rebushing throttle bores, what to use [Re: RapidRobert] #987352
05/07/11 12:09 AM
05/07/11 12:09 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
RR ... how badly are they worn ?
Re: rebushing throttle bores, what to use [Re: BeEtLeJuIcE !] #987353
05/07/11 12:44 AM
05/07/11 12:44 AM
Not sure bro but I want to do em (dual AFB's going on a 451) to b proactive & I want to spend some money plus they're 40 + years old
Re: rebushing throttle bores, what to use [Re: RapidRobert] #987354
05/07/11 12:49 AM
05/07/11 12:49 AM
Florida STAYcation
Florida STAYcation
I have never REbushed a base plate ever. Never ran into a carb that I was going to do or use that needed it...... B U T ... I have heard of some that were soooo bad that they caused severe vacuum leaks ...and actually were ...
Your point about getting them in STRAIGHT and TRUE should be a concern. I would say take them to a small machine shop locally.
Re: rebushing throttle bores, what to use [Re: RapidRobert] #987355
05/07/11 01:25 PM
05/07/11 01:25 PM
utah
jjl Offline
jjl  Offline
utah
Yes, goodson sells them and the related tooling.As a side note,If the rebuild is basically stock you can get + .o15 valves.Larger on the stems and the valve diameter.
Re: rebushing throttle bores, what to use [Re: RapidRobert] #987356
05/07/11 06:35 PM
05/07/11 06:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Reaming the baseplate oversize for bushings requires a reamer with a pilot that's long enough to extend all the way through the baseplate before the flutes make contact. This is the only way to prevent crooked throttle shaft bores.
Re: rebushing throttle bores, what to use [Re: John_Kunkel] #987357
05/07/11 08:58 PM
05/07/11 08:58 PM
Thank you John & a guy has the right stuff & wants 25 a carb so I might just let him go ahead
Re: rebushing throttle bores, what to use [Re: RapidRobert] #987358
05/07/11 09:45 PM
05/07/11 09:45 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I use a home made version of the method sold here Throttle Shaft Repair Tools
Works great!
Re: rebushing throttle bores, what to use [Re: ScottSmith_Harms] #987359
05/07/11 09:48 PM
05/07/11 09:48 PM
Works great!
Yeah I didn't mind the 25 (X2) but I wanted to do it myself (pride) plus it ain't rocket science
Re: rebushing throttle bores, what to use [Re: RapidRobert] #987360
05/07/11 09:51 PM
05/07/11 09:51 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
BTW I HIGHLY reccomend a good cutting lube when cutting the aluminum, you don't want it the cutter gall or bind up mid way or it can get ugly in a hurry!
Re: rebushing throttle bores, what to use [Re: ScottSmith_Harms] #987361
05/07/11 09:54 PM
05/07/11 09:54 PM
I have 2 identical 4131S AFB's & for sure dont want to mess one up
