opinion on build #986154
05/04/11 05:19 PM
05/04/11 05:19 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
okay motor heads what hp do ya think
70 440hp /stk. hp manifolds
pistons changed to 9:5
bored 30 over
mr 6pk #3 grind cam
906 heads are stock w/ hvy springs per mr 6pk
stock 6pk carbs adjusted to mr 6pk specs
electronic ign timing set at mr 6pk specs
motor is in a 69a12 clone with dana 60 373 gears & a 23 spline 4spd
with stock redline bias.
what do you think she will run in Quarter & hp est.
thanks
Re: opinion on build [Re: AB&E] #986155
05/04/11 05:32 PM
05/04/11 05:32 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
13.20 with those tires 12.90 if you can get it to hook.
Coming soon!!!!
Re: opinion on build [Re: Mr.Yuck] #986156
05/04/11 06:24 PM
05/04/11 06:24 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
that would work for a street car Any estimate of hp I was thinking around 425-450hp ?
Re: opinion on build [Re: AB&E] #986157
05/04/11 06:47 PM
05/04/11 06:47 PM
FT Campbell, KY / Clarksville,...
The Cuda Guy Offline
With the info provided 450 sounds dead on.
Don
Street/Strip 73 Barracuda
Re: opinion on build [Re: The Cuda Guy] #986158
05/04/11 07:00 PM
05/04/11 07:00 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
curiosity with 30 over pistons what cubes would it be now??
thanks for the info abe
Re: opinion on build [Re: AB&E] #986159
05/04/11 07:02 PM
05/04/11 07:02 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
446" at .030 over
Re: opinion on build [Re: AB&E] #986160
05/04/11 08:18 PM
05/04/11 08:18 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I assume that the stock heads means unported and the race weight is 3900lbs.
Here are the two extremes IMO:
1) If you don't spend a bunch of time at the track testing, tuning, and practicing and you only go out once in the middle of the summer: 13.7 at 104.
2) If you track test, tune and practice driving, in good air: 12.70 at 110.
Re: opinion on build [Re: BSB67] #986161
05/04/11 10:40 PM
05/04/11 10:40 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
Agree with the above...
Driver mod is always an important one to go along with the test n' tune. I've seen Hemi 'cuda barely get out of the 15's. Yet that same car on that same day with a little work and a whole lot better driving could have see 12's too imo.
In your case, all things ideal including traction/suspension, 12.7's 108.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: opinion on build [Re: AB&E] #986162
05/05/11 07:56 PM
05/05/11 07:56 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
bored 30 over
mr 6pk #3 grind cam
thanks
Well things have changed (due to machine shop)
I now have
kb237 pistons 40 over
deck has been shaved 200000 i think
heads are stk form 346s
everything else is same do you think there will be much of a change in figures on hp & 1/4 mile
