column mount b/u switch to trans conversion ? #985147
05/02/11 10:12 PM
05/02/11 10:12 PM
Royersford, PA
bschargerse Offline OP
Royersford, PA
Has anyone ever converted their column mounted reverse light switch to a transmission mounted one (later 3 prong model)? I'm referring to a Torqueflite. The column mounted switch is broken on my '66 Chrysler. I would like to convert it from a standard single prong neutral safety switch to a combo ns/rev switch. Do I also need to change the "rooster comb" in the trans too?
Thanks.
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: column mount b/u switch to trans conversion ? [Re: bschargerse] #985148
05/03/11 07:38 AM
05/03/11 07:38 AM
Royersford, PA
Royersford, PA
bump....
Re: column mount b/u switch to trans conversion ? [Re: bschargerse] #985149
05/03/11 12:28 PM
05/03/11 12:28 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
No.
Re: column mount b/u switch to trans conversion ? [Re: bschargerse] #985150
05/03/11 12:43 PM
05/03/11 12:43 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Many years ago, I changed from the column to the trans for my 67 Barracuda. I did not change the Rooster comb as you call it, but I had a newer trans. However,I never heard of anyone having to swap the comb though. I am sure you should be good to go if you swap the switch, and move the wiring as I did.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: column mount b/u switch to trans conversion ? [Re: doctor_mopar] #985151
05/03/11 03:33 PM
05/03/11 03:33 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Many years ago,
Many ? ....like a huNdred or so ? .... like a 1867 Barracuda CHARIOT ?
TELL US how it was then .....
Re: column mount b/u switch to trans conversion ? [Re: dOrk !] #985152
05/03/11 04:40 PM
05/03/11 04:40 PM
Winlock, Wa
fshd4it Offline
fshd4it  Offline
Winlock, Wa
I put a single wire NSS trans in a '74 duster once. I tried to change just the manual lever assy. to match with the 3 pin switch, but it interfered with the governor plug end plate. I ended up swapping out the whole valve body for a newer one, seemed to work fine.
In order to know what you want, you'll probably have to find out what you don't want.
Re: column mount b/u switch to trans conversion ? [Re: bschargerse] #985153
05/03/11 06:37 PM
05/03/11 06:37 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
If you want to use the 3-prong NSS in a '66-'68 transmission you'll have to change the roostercomb in the valve body and only a '69 or '70 will work. Or you can change the entire valve body.
Re: column mount b/u switch to trans conversion ? [Re: John_Kunkel] #985154
05/04/11 07:46 AM
05/04/11 07:46 AM
Royersford, PA
Royersford, PA
Thanks!
