column mount b/u switch to trans conversion ?
#985147
05/02/11 10:12 PM
05/02/11 10:12 PM
Posts: 2,507 Royersford, PA
bschargerse
Royersford, PA
Has anyone ever converted their column mounted reverse light switch to a transmission mounted one (later 3 prong model)? I'm referring to a Torqueflite. The column mounted switch is broken on my '66 Chrysler. I would like to convert it from a standard single prong neutral safety switch to a combo ns/rev switch. Do I also need to change the "rooster comb" in the trans too? Thanks.
Brian - 1971 Dodge Challenger "The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: column mount b/u switch to trans conversion ?
[Re: bschargerse]
#985150
05/03/11 12:43 PM
05/03/11 12:43 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
Many years ago, I changed from the column to the trans for my 67 Barracuda. I did not change the Rooster comb as you call it, but I had a newer trans. However,I never heard of anyone having to swap the comb though. I am sure you should be good to go if you swap the switch, and move the wiring as I did.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: doctor_mopar]
#985151
05/03/11 03:33 PM
05/03/11 03:33 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Many years ago,
Many ? ....like a huNdred or so ? .... like a 1867 Barracuda CHARIOT ?
TELL US how it was then .....
[Re: bschargerse]
#985153
05/03/11 06:37 PM
05/03/11 06:37 PM
Posts: 25,729 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you want to use the 3-prong NSS in a '66-'68 transmission you'll have to change the roostercomb in the valve body and only a '69 or '70 will work. Or you can change the entire valve body.
