Need some info from Experienced Hemi builders please
#983036
04/30/11 09:29 AM
04/30/11 09:29 AM
Posts: 1,113 Lost in Pooler, GA
Gumbydammit
Lost in Pooler, GA
I'm looking into ordering some pieces for my friend's Hemi project. He has a KB alum standard cam location block on order. Wants to go with a 4.500 stroke and oliver rods. Two opinions are that the rotating assy will fit no problem, and two other well known builders say no way.
Which is it? The previous combo ran a 4.375 stroke with Howards aluminum rods in a KB block with the standard cam height. This block will also be standard cam bore height.
If you have build a few KB hemis with a 4.500 stroke and had the stock cam bore location, please chime in as to what if any issues you had so I can get some parts ordered.
Thanks!
I'm Gumby dammit!
Re: Need some info from Experienced Hemi builders please
[Re: joshking440]
#983040
04/30/11 09:58 AM
04/30/11 09:58 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Holy shi+. It's Darren. How are things going man. I haven't seen you around in a while. [/quote
Hey man, been working like crazy, and as a result have gone crazy
[Re: joshking440]
#983042
04/30/11 10:17 AM
04/30/11 10:17 AM
Gumbydammit
Lost in Pooler, GA
Ken Black said sure, nor problem. Barton said the rod would hit the cam.
It has an external pickup, so no tube issue. I just wanted to get my stuff straight before I order something I can't return.
Thanks.
I'm Gumby dammit!
[Re: Gumbydammit]
#983044
04/30/11 11:07 PM
04/30/11 11:07 PM
Posts: 2,117 Byron, NY
W.I.N. Racing
Byron, NY
If you have an std dimension (cam location) KB block and a 4.5 stroke with Mopar rod journals it will clear the cam but it is close, if the cam is not degreed correctly or if it walks forward it will hit the #2 or 7 rod (I think its been a while) Also you will have to make space at the bottom of the cylinders on both the cam side and the skirt side. other that it drops right in
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: dthemi]
#983047
05/01/11 11:48 PM
05/01/11 11:48 PM
Gumbydammit
Lost in Pooler, GA
Barton said the rod would hit the cam. The question was with the 7.100 rod length, and that seems to be addressed here too. So it looks like we'll be ok, and we will check everything of course.
Thanks guys!
I'm Gumby dammit!
[Re: Gumbydammit]
#983048
05/02/11 12:16 AM
05/02/11 12:16 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
World Block 4.5 bore 4.5 stroke crank and 7.1 long manley rods cleared everything... I could even run internal oil pickup with that block.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#983049
05/02/11 09:05 AM
05/02/11 09:05 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
KB / RBRE built motor - Oliver 6.86 chevy rods , 4.6125 Bryant crank . No hit w/ standard can loc'n . Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: chryco]
#983050
05/02/11 08:06 PM
05/02/11 08:06 PM
Posts: 253 Smithfield, Rhode Island
Mulehead
Call Ken Black and 4.500 with Chevy Journals will clear and all so 4.500 with Mopar Journals will clear too.Most of the engines going out the door are 4.500 X 4.500 ---572ci
Ain't nuthin like a HEMI !
