Need some info from Experienced Hemi builders please #983036
04/30/11 09:29 AM
04/30/11 09:29 AM
Lost in Pooler, GA
Gumbydammit Offline OP
Lost in Pooler, GA
I'm looking into ordering some pieces for my friend's Hemi project. He has a KB alum standard cam location block on order. Wants to go with a 4.500 stroke and oliver rods. Two opinions are that the rotating assy will fit no problem, and two other well known builders say no way.
Which is it? The previous combo ran a 4.375 stroke with Howards aluminum rods in a KB block with the standard cam height. This block will also be standard cam bore height.
If you have build a few KB hemis with a 4.500 stroke and had the stock cam bore location, please chime in as to what if any issues you had so I can get some parts ordered.
Thanks!
I'm Gumby dammit!
Re: Need some info from Experienced Hemi builders please [Re: Gumbydammit] #983037
04/30/11 09:46 AM
04/30/11 09:46 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
If it's BBC rod size, no problem.
Re: Need some info from Experienced Hemi builders please [Re: dthemi] #983038
04/30/11 09:48 AM
04/30/11 09:48 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Holy shi+. It's Darren. How are things going man. I haven't seen you around in a while.
Re: Need some info from Experienced Hemi builders please [Re: dthemi] #983039
04/30/11 09:53 AM
04/30/11 09:53 AM
Lost in Pooler, GA
Lost in Pooler, GA
Yup BBC rod Journal. Thanks Darren.
I'm Gumby dammit!
Re: Need some info from Experienced Hemi builders please [Re: joshking440] #983040
04/30/11 09:58 AM
04/30/11 09:58 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Holy shi+. It's Darren. How are things going man. I haven't seen you around in a while. [/quote
Hey man, been working like crazy, and as a result have gone crazy
Re: Need some info from Experienced Hemi builders please [Re: Gumbydammit] #983041
04/30/11 10:01 AM
04/30/11 10:01 AM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
Chevy journal rods should clear the cam but look at everything including the oil tube if you are using a stock one.
Call KB and ask them, make sure you can ID the block
Don't assume anything=check everything
Re: Need some info from Experienced Hemi builders please [Re: joshking440] #983042
04/30/11 10:17 AM
04/30/11 10:17 AM
Lost in Pooler, GA
Lost in Pooler, GA
Ken Black said sure, nor problem. Barton said the rod would hit the cam.
It has an external pickup, so no tube issue. I just wanted to get my stuff straight before I order something I can't return.
Thanks.
I'm Gumby dammit!
Re: Need some info from Experienced Hemi builders please [Re: Gumbydammit] #983043
04/30/11 10:36 AM
04/30/11 10:36 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I have a 4.5" stroke with chevy journal and GRP alum rods. No clearance issues with cam or block. I did have KB do the machining to clear. You can see in the pic where they took off material at the bottom of the cylinders.
Re: Need some info from Experienced Hemi builders please [Re: Gumbydammit] #983044
04/30/11 11:07 PM
04/30/11 11:07 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
If you have an std dimension (cam location) KB block and a 4.5 stroke with Mopar rod journals it will clear the cam but it is close, if the cam is not degreed correctly or if it walks forward it will hit the #2 or 7 rod (I think its been a while)
Also you will have to make space at the bottom of the cylinders on both the cam side and the skirt side. other that it drops right in
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Need some info from Experienced Hemi builders please [Re: W.I.N. Racing] #983045
05/01/11 07:35 AM
05/01/11 07:35 AM
pa
572charger Offline
572charger  Offline
pa
should not hit. ive got a 2003 mopar block with a 4.750 callies and oliver 2.2 [chevy rod] 7.100 long with no grinding except at the oil pick up tube !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Need some info from Experienced Hemi builders please [Re: dthemi] #983046
05/01/11 08:52 AM
05/01/11 08:52 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
THE TRUTH IS HE'S INVOLVED WITH FARM ANIMALS !!!!
SHOW HORSES
home of the
Sox and Martin Hemi Duster
Re: Need some info from Experienced Hemi builders please [Re: dthemi] #983047
05/01/11 11:48 PM
05/01/11 11:48 PM
Lost in Pooler, GA
Lost in Pooler, GA
Barton said the rod would hit the cam. The question was with the 7.100 rod length, and that seems to be addressed here too. So it looks like we'll be ok, and we will check everything of course.
Thanks guys!
I'm Gumby dammit!
Re: Need some info from Experienced Hemi builders please [Re: Gumbydammit] #983048
05/02/11 12:16 AM
05/02/11 12:16 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
World Block 4.5 bore
4.5 stroke crank and 7.1 long manley rods cleared everything... I could even run internal oil pickup with that block.
Re: Need some info from Experienced Hemi builders please [Re: Bob_Coomer] #983049
05/02/11 09:05 AM
05/02/11 09:05 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
KB / RBRE built motor - Oliver 6.86 chevy rods , 4.6125 Bryant crank . No hit w/ standard can loc'n .
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Need some info from Experienced Hemi builders please [Re: chryco] #983050
05/02/11 08:06 PM
05/02/11 08:06 PM
Smithfield, Rhode Island
Mulehead Offline
Mulehead  Offline
Call Ken Black and 4.500 with Chevy Journals will clear and all so 4.500
with Mopar Journals will clear too.Most of the engines going out the door are 4.500 X 4.500 ---572ci
Ain't nuthin like a HEMI !
