Opinions needed(NAY or YAY) #983022
04/30/11 08:46 AM
04/30/11 08:46 AM
canada,NB
jb15 Offline OP
jb15  Offline OP
canada,NB
Car is hitting 150mph now. will closing in the grill area and adding a chin spoiler like I've mocked up with foam to fiberglass, help with areodynimcs, or be a lot of work for nothing?.
the chin spoiler look alright or not?, varied opinions here on the home front ,
Thanks,Jim
Re: Opinions needed(NAY or YAY) [Re: jb15] #983023
04/30/11 08:55 AM
04/30/11 08:55 AM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
YAY! Pushing the air around and over the car has to be an advantage over going through the car.
SS/DA 1924
Re: Opinions needed(NAY or YAY) [Re: jb15] #983024
04/30/11 08:59 AM
04/30/11 08:59 AM
Q
Quicktree Offline
Quicktree  Offline
Q
nay, it's fugly
Re: Opinions needed(NAY or YAY) [Re: jb15] #983025
04/30/11 09:08 AM
04/30/11 09:08 AM
Lehigh Acres, Florida
rickstershemi Offline
I say Yay and once is all together & painted will look sharp
Rickster
Re: Opinions needed(NAY or YAY) [Re: rickstershemi] #983026
04/30/11 09:15 AM
04/30/11 09:15 AM
canada,NB
jb15 Offline OP
jb15  Offline OP
canada,NB
I've made a glass bumper to bond to the filled valance as well, fugly? ahh crap ,
Re: Opinions needed(NAY or YAY) [Re: jb15] #983027
04/30/11 09:25 AM
04/30/11 09:25 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
I'd rather slow down than ugly up a Cuda...
Re: Opinions needed(NAY or YAY) [Re: jb15] #983028
04/30/11 09:47 AM
04/30/11 09:47 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
I like the idea of closing off the big opening under the bumper for aerodynamics sake. If you do that, paint it black so it doesn't stand out so much(the filler piece, not the car).
Instead of the chin spoiler, what about an airpan under the car from the valance back to the K-frame? I'm no expert, but I would think less frontal area would be better.
Another thing to try is narrow the bumper so the ends are closer to the fenders.
Re: Opinions needed(NAY or YAY) [Re: Dart1031] #983029
04/30/11 10:12 AM
04/30/11 10:12 AM
canada,NB
jb15 Offline OP
jb15  Offline OP
canada,NB
taped the glass bumper I made on for a better visual,running a pan already, it has helped.
Re: Opinions needed(NAY or YAY) [Re: jb15] #983030
04/30/11 10:22 AM
04/30/11 10:22 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
What about putting lexan behind the grille? I've seen this done and heard it made a difference. And it doesn't look as bad as covering the front of the grille.
Re: Opinions needed(NAY or YAY) [Re: Dart1031] #983031
04/30/11 10:24 AM
04/30/11 10:24 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
NONE of the above....WELL over 150...
Re: Opinions needed(NAY or YAY) [Re: DaKuda] #983032
04/30/11 10:33 AM
04/30/11 10:33 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Good point, lol. And I don't think Dan Dye's car had anything like that either. But it's his car to do with what he want's. I was just offering my Personally I couldn't cut up a nice E-body cuda.
Re: Opinions needed(NAY or YAY) [Re: Dart1031] #983033
04/30/11 07:39 PM
04/30/11 07:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Aerodynamically, it'll work. Closing off the recessed grille & headlamp area so it's flat or even convex is best aero solution. Corners of the air dam could be rounder but what you've designed will work. Venting the hood close to the firewall has also been proven to work.
Aesthetically, your decision, of course. Personally I like the stock design, but its aero can be improved if that matters for your goals more than stock appearance.
Same goes for a spoiler on the trunk lid; the car will almost certainly pick up MPH and maybe even top-end traction, but it's also an aesthetic issue.
Re: Opinions needed(NAY or YAY) [Re: topside] #983034
04/30/11 07:44 PM
04/30/11 07:44 PM
Arizona
Chucklehead Offline
Chucklehead  Offline
Arizona
YAY if it takes you to where you want to be. Different is better.
Still Broke
Re: Opinions needed(NAY or YAY) [Re: DaKuda] #983035
04/30/11 08:33 PM
04/30/11 08:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With alot more power
For the OP
Areo really help... those are 2 big buckets they call
a grille... the whole idea is to get the air either
up or around the sides... if you let it up and over
use that air to your benefit either into the scoop
or so it hits a rear wing for down force
