Aluminum Water Pump and Housing VS Stock, For Weight? #979556
04/24/11 02:49 PM
04/24/11 02:49 PM
Arkansas, U.S.
bill440cars Offline OP
The New Guy
The New Guy
Arkansas, U.S.
Anyone know, right off, what kind of weight I might drop, by going to an aluminum water pump and housing? Seems like it would help, at least. Input appreciated. BTW, we're talking about a 440 that's going into a '92 Dakota.
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: bill440cars] #979557
04/24/11 02:50 PM
04/24/11 02:50 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I would think 6-8 lbs. Not really worth the cost and not much of a weight loss. If you add in aluminum heads and intake though, it starts to add up.
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: bill440cars] #979558
04/24/11 02:57 PM
04/24/11 02:57 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I'm thinking more than 6-8 lbs. I just weighed a stock BB housing (no Water pump) and its 17 lbs. Anybody got an aluminum one laying around to weigh?
I know the water pump savings is really slight--maybe a pound, simply because they are so small.
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: Pacnorthcuda] #979559
04/24/11 03:16 PM
04/24/11 03:16 PM
Arkansas, U.S.
The New Guy
The New Guy
Arkansas, U.S.
I knew that the pump itself wouldn't make much difference, but I can get the pump and the housing for about $100 and I already have an Edelbrock 6 Pack manifold. I'm not financially able to go as far as aluminum heads though. I was just thinking about adding the aluminum housing and pump, to help take some off of the weight of the engine itself. Of course, it also helps in the looks department as well. I WOULD be interested in knowing thew weight of the aluminum pieces, just to see the difference. Appreciate the input. I would think the difference would be worthwhile, but thought I'd throw it out there, to see if I could find out how MUCH difference there was. Thanks.
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: bill440cars] #979560
04/24/11 03:30 PM
04/24/11 03:30 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I just weighed the set from Mancini and they weigh in at
4.6 pounds for the housing
2.6 pounds for the pump
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: Pyper70] #979561
04/24/11 03:36 PM
04/24/11 03:36 PM
So the housing alone is 17-4.6 = 12.4 lbs.
Sounds like about $10/lb of savings. Not the cheapest, but if your on a diet....
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: Pacnorthcuda] #979562
04/24/11 03:38 PM
04/24/11 03:38 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
My numbers are from an aluminum set...You mentioned the 17 lbs was for a cast iron though
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: Pyper70] #979563
04/24/11 03:45 PM
04/24/11 03:45 PM
Correct. So the AL housing is a 12.4lb (+/- a bit for error, I used a bathroom scale ) savings. Maybe 1- 1.5 lbs for the pump?
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: Pacnorthcuda] #979564
04/24/11 03:47 PM
04/24/11 03:47 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Oh SAVINGS....I thought you were trying to say it was the actual weight....I tried the bathroom scale too...didnt work out too well...I just baptized my kitchen counter cooking scale with car parts.
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: Pyper70] #979565
04/24/11 03:51 PM
04/24/11 03:51 PM
Arkansas, U.S.
The New Guy
The New Guy
Arkansas, U.S.
With 12.4 lbs difference in the the water pump housing, the difference between a stock intake and the aluminum Edelbrock and whatever the little dab of difference between the aluminum water pump and the stock one would be, will help some, in getting a little weight off of the front end. All the A/C stuff will be gone and the battery is going to the bed of the truck. I know the 440 is pretty heavy by itself and I'm trying to drop a little of that, if I can. Again, I appreciate the input here. Bill
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: bill440cars] #979566
04/24/11 03:57 PM
04/24/11 03:57 PM
Those combined changes are probably more than the difference between an RB and and LA engine. At least on the front end.
Now imagine a set of eddy or source heads.
Course you're still handicapped by the fact you're dealing with a TRUCK. What does IT weigh?
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: bill440cars] #979567
04/24/11 06:00 PM
04/24/11 06:00 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Apples to apples comparison between iron and aluminum on the same scale two minutes apart. 7.6 lbs difference.
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: Pacnorthcuda] #979568
04/24/11 06:14 PM
04/24/11 06:14 PM
Arkansas, U.S.
The New Guy
The New Guy
Arkansas, U.S.
I hear ya, on the heads, but with what I've got going, I can't swing a set of heads. I've also got a slightly modded '07 Charger R/T, a (also slightly modded) '69 Plymouth GTX, an '85 Shelby Charger (Turbo) that is pretty nicely modded and some motorcycles, to include an '80 Honda CBX and an '83 Kawasaki GPZ1100. Not much money to spare, especially considering what I've already got in the Dakota and I've got to do some work on the GTX.
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: BSB67] #979569
04/24/11 06:21 PM
04/24/11 06:21 PM
Arkansas, U.S.
The New Guy
The New Guy
Arkansas, U.S.
Have to say, right here, that I'm liking you Charger. I had a red '66 (383/4sp/Sure Grip), back in '69 and that one was a great runner. Beautiful car and performed pretty good, for being stock. Wish I still had THAT ONE.
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: bill440cars] #979570
04/24/11 08:39 PM
04/24/11 08:39 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Thanks.
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: bill440cars] #979571
04/24/11 08:43 PM
04/24/11 08:43 PM
Re: Aluminum Water Pump and Housing VS Stock, For Weight? #979572
04/25/11 12:09 AM
04/25/11 12:09 AM
Arkansas, U.S.
The New Guy
The New Guy
Arkansas, U.S.
http://www.moparts.org/Tech/Archive/bb/36.html
Thanks for that, I hadn't even thought about the starter at this point.
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: bill440cars] #979573
04/25/11 12:02 PM
04/25/11 12:02 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Aluminum housing, yes, but there's not much to gain with the aluminum pumps. They are so thick that some OEM iron pumps weigh the same.
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: B5 Bee] #979574
04/25/11 06:46 PM
04/25/11 06:46 PM
QLD Australia
Keith Black® Offline
QLD Australia
I have one you could have for free... but it's in Australia
Darren Beale
Keith Black Racing Engines®
Re: Aluminum Water Pump and Housing VS Stock, For Weight? [Re: Keith Black®] #979575
04/25/11 10:15 PM
04/25/11 10:15 PM
When I added more fruits/veggies to my diet & took up jogging I lost 50 lbs. Sorry just couldn't resist
