Re: Aluminum Water Pump and Housing VS Stock, For Weight?
[Re: bill440cars]
#979560
04/24/11 03:30 PM
04/24/11 03:30 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
I just weighed the set from Mancini and they weigh in at
4.6 pounds for the housing 2.6 pounds for the pump
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pacnorthcuda]
#979562
04/24/11 03:38 PM
04/24/11 03:38 PM
Pyper70
Athens, Greece
My numbers are from an aluminum set...You mentioned the 17 lbs was for a cast iron though
[Re: Pyper70]
#979563
04/24/11 03:45 PM
04/24/11 03:45 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
Correct. So the AL housing is a 12.4lb (+/- a bit for error, I used a bathroom scale ) savings. Maybe 1- 1.5 lbs for the pump?
[Re: bill440cars]
#979566
04/24/11 03:57 PM
04/24/11 03:57 PM
Pacnorthcuda
With 12.4 lbs difference in the the water pump housing, the difference between a stock intake and the aluminum Edelbrock and whatever the little dab of difference between the aluminum water pump and the stock one would be, will help some, in getting a little weight off of the front end. All the A/C stuff will be gone and the battery is going to the bed of the truck. I know the 440 is pretty heavy by itself and I'm trying to drop a little of that, if I can. Again, I appreciate the input here. Bill
Those combined changes are probably more than the difference between an RB and and LA engine. At least on the front end. Now imagine a set of eddy or source heads.
Course you're still handicapped by the fact you're dealing with a TRUCK. What does IT weigh?
[Re: Pacnorthcuda]
#979568
04/24/11 06:14 PM
04/24/11 06:14 PM
Posts: 19 Arkansas, U.S.
bill440cars
The New Guy
The New Guy
Arkansas, U.S.
I hear ya, on the heads, but with what I've got going, I can't swing a set of heads. I've also got a slightly modded '07 Charger R/T, a (also slightly modded) '69 Plymouth GTX, an '85 Shelby Charger (Turbo) that is pretty nicely modded and some motorcycles, to include an '80 Honda CBX and an '83 Kawasaki GPZ1100. Not much money to spare, especially considering what I've already got in the Dakota and I've got to do some work on the GTX.
[Re: BSB67]
#979569
04/24/11 06:21 PM
04/24/11 06:21 PM
bill440cars
The New Guy
The New Guy
Arkansas, U.S.
Apples to apples comparison between iron and aluminum on the same scale two minutes apart. 7.6 lbs difference.
Have to say, right here, that I'm liking you Charger. I had a red '66 (383/4sp/Sure Grip), back in '69 and that one was a great runner. Beautiful car and performed pretty good, for being stock. Wish I still had THAT ONE.
[Re: bill440cars]
#979571
04/24/11 08:43 PM
04/24/11 08:43 PM
