Re: Best way to clean oil/grease from clutch disc??
[Re: wicked]
#979226
04/24/11 03:33 AM
04/24/11 03:33 AM
Posts: 4,848 Memphis
HemiRick
Memphis
yep they're cheap you need a new one.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: GTXX]
#979229
04/24/11 11:48 AM
04/24/11 11:48 AM
Challenger 1
Cincinnati, Ohio
I've seen truck mechanics use a propane torch and lots of rags on brake shoes after replacing an axle seal. The clutch disc is the same stuff, but my guess is that it won't ever be as good as new no matter what you do.
Steam pressure washer works good for oilly brake shoes/pads.
But considing what tough job it is pulling the trans, I'd replace it. My
[Re: Challenger 1]
#979230
04/24/11 12:08 PM
04/24/11 12:08 PM
Posts: 671 Wisconsin USA
Bill MeLater
Wisconsin USA
But considing what tough job it is pulling the trans, I replace it. My
I've had it work.....BUT, Not often enoguh to take the chance...
