Best way to clean oil/grease from clutch disc?? #979224
04/24/11 01:23 AM
04/24/11 01:23 AM
Lansing, MI
70gtx440dana Offline OP
Lansing, MI
I have a new never installed factory style 18 spline clutch disc that got some oil/grease spilled on to the friction surfaces. Can I clean this well enough to use safely with brake cleaner or is there another trick out there that is more full proof? Thanks!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Best way to clean oil/grease from clutch disc?? [Re: 70gtx440dana] #979225
04/24/11 02:38 AM
04/24/11 02:38 AM
md
W
wicked Offline
wicked  Offline
W
md
The oil embeds in the friction material, think your best choice is another one.
Re: Best way to clean oil/grease from clutch disc?? [Re: wicked] #979226
04/24/11 03:33 AM
04/24/11 03:33 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
yep they're cheap you need a new one.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Best way to clean oil/grease from clutch disc?? [Re: HemiRick] #979227
04/24/11 08:31 AM
04/24/11 08:31 AM
IN
ahy Offline
ahy  Offline
IN
It may not be ideal, but a good long blast of brake cleaner will remove most of the oil.
Re: Best way to clean oil/grease from clutch disc?? [Re: 70gtx440dana] #979228
04/24/11 10:51 AM
04/24/11 10:51 AM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
I've seen truck mechanics use a propane torch and lots of rags on brake shoes after replacing an axle seal. The clutch disc is the same stuff, but my guess is that it won't ever be as good as new no matter what you do.
Re: Best way to clean oil/grease from clutch disc?? [Re: GTXX] #979229
04/24/11 11:48 AM
04/24/11 11:48 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Steam pressure washer works good for oilly brake shoes/pads.
But considing what tough job it is pulling the trans, I'd replace it. My
Re: Best way to clean oil/grease from clutch disc?? [Re: Challenger 1] #979230
04/24/11 12:08 PM
04/24/11 12:08 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
But considing what tough job it is pulling the trans, I replace it. My
I've had it work.....BUT, Not often enoguh to take the chance...
Re: Best way to clean oil/grease from clutch disc?? [Re: 70gtx440dana] #979231
04/24/11 12:15 PM
04/24/11 12:15 PM
Kirkland, Washington
Pacnorthcuda Offline
I've clean oil soaked brake shoes with brake cleaner and they are fine but a Clutch Disc???? I agree--too much work if it slips. Buy a new one.
Re: Best way to clean oil/grease from clutch disc?? [Re: Pacnorthcuda] #979232
04/24/11 02:08 PM
04/24/11 02:08 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have successfully re-used brake shoes that got oiled down from a faulty axle seal by burning the oil out with a torch. If it was me I'd buy a new disc unless this is a budget beater or winter car.
Your other option is to take it to a clutch shop and have them look at it.
Re: Best way to clean oil/grease from clutch disc?? [Re: Jeremiah] #979233
04/24/11 02:28 PM
04/24/11 02:28 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Suppose you do get it cleaned real good and it slips after all that work. Replace it now and save yourself a headache later on.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Best way to clean oil/grease from clutch disc?? [Re: 70sixpkrt] #979234
04/26/11 08:26 AM
04/26/11 08:26 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Many years ago I had some brake shoes that were covered in fluid from a leaky wheel cylinder.
I put them in my Mum's oven while she was out (can't believe I did that!) and they were as good as new!
But would make sure you do it outside or in an old oven. Or as others have said with the effort of doing it again if it didn't work, think about getting a new one....
