installed powergllide... #978869
04/23/11 02:03 PM
04/23/11 02:03 PM
KY
juicedcuda Offline OP
KY
Installed a power glide with JW bell housing behind BB in my 'Cuda. I used the supplied spacer for the snout in the bell housing. When using the spacer you have to use the supplied starter shims obviously to be able to tighten down the two starter bolts. Once my starter snout is all the way in the spacer and the 5 supplied shims are in there, there is still a 1/8" to 3/16" gap between the bell housing and starter flange, so I added additional shims to take up the gap. Now when the starter is engaged there isn't enough gear hitting the teeth on the flywheel. What do I do? And why wouldn't JW supply enough shims to take up the gap the spacer puts the starter out?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: installed powergllide... [Re: juicedcuda] #978870
04/23/11 05:22 PM
04/23/11 05:22 PM
mogadore ohio 44260
racingblues1426 Offline
mogadore ohio 44260
i've run the same combo--jwultra bell, with glide and turbo 400. I never had to use any shims. These combos were with a 9523 powermaster starter. That might be your problem--wrong starter.
Re: installed powergllide... [Re: racingblues1426] #978871
04/23/11 06:37 PM
04/23/11 06:37 PM
KY
KY
Do you run an 1/8" mid plate?
Re: installed powergllide... [Re: racingblues1426] #978872
04/23/11 06:38 PM
04/23/11 06:38 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I`m also using the same set up with a Mopar mini starter sans shims here as well .
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: installed powergllide... [Re: chryco] #978873
04/23/11 06:54 PM
04/23/11 06:54 PM
PA
moparacer Online content
moparacer  Online Content
PA
I have a 1/4 inch aluminum mid plate with a ultra bell and don't use any shims either.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: installed powergllide... [Re: juicedcuda] #978874
04/23/11 11:28 PM
04/23/11 11:28 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Remove the snout. You don't need it. I have never been able to get one to fit all the way in the hole in the bell for it. Shim the starter so you have .100 between the stater gear and the ring gear. That will give you full engagement of the gears.
Re: installed powergllide... [Re: Dabee] #978875
04/24/11 12:45 AM
04/24/11 12:45 AM
KY
KY
Remove the spacer or remove the snout of the starter?
Re: installed powergllide... [Re: juicedcuda] #978876
04/24/11 02:54 AM
04/24/11 02:54 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I am not sure which flywheel and center hub you are using but there are different set ups. There are some where the hub goes onto the crank flange first and the flywheel on top of it. The others mount the flywheel first and hub second. The starter ring gear winds up in a different place when compared. Pictured are various hub adapters.
Some worked better when installed first rather than the flywheel. Nearly all required a spacer to pull the starter back from the wheel. In most cases the same size as the midplate.
home of the
Sox and Martin Hemi Duster
Re: installed powergllide... [Re: HEMIFRED] #978877
04/24/11 02:55 AM
04/24/11 02:55 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
they have come in different thicknesses
home of the
Re: installed powergllide... [Re: HEMIFRED] #978878
04/24/11 02:57 AM
04/24/11 02:57 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
and various spacers came with them others are home made
home of the
Re: installed powergllide... [Re: HEMIFRED] #978879
04/24/11 03:25 AM
04/24/11 03:25 AM
Eldridge, IA
HR5058 Offline
HR5058  Offline
Eldridge, IA
Remove the spacer and shim to as suggested above. That is what I ended up doing on my small block and no issues at all. Chuck
Re: installed powergllide... [Re: HEMIFRED] #978880
04/24/11 08:44 AM
04/24/11 08:44 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
As Fred stated sometimes you have to mix and match because of all the possible combinations of mid plates. I had to make my crank adapter but I'm using jw bell and I think it is a tci wheel.If I read your post right it sounds like the starter snout is getting hung up in the pilot hole. Did you dry fit your starter before you put the transmission in? When I fit my starter on the bench the first time it would not engage all the way. The snout and pilot needed to be cleaned up a bit. I can see having to shim the starter to get the right engagement on the ring gear but the starter should go in tight to the bell housing unless there is interference in the pilot hole.
Re: installed powergllide... [Re: mac56] #978881
04/24/11 09:23 AM
04/24/11 09:23 AM
Iowa
coronetville Offline
Iowa
some cranks have a "end" that is longer or shorter than others,pull the trans. and measure the distance (with flywheel on) from the face of the flywheel [tranny side] to the the back of the block. Then put the converter on the transmission. VERY IMPORTANT, make sure the converter is all the way on the snout. Then measure the distance from the transmission bell housing to one of the mounting pads on the converter. There should be only 1/8 of on inch of play difference. This 1/8" has to be longer than on the transmission side than the engine side. You might have to have the converter machined for the difference like I did. Also remember if you have to take material off the converter mounting pads you must also remove the same amount off the snout of the converter (the end that fits in the crankshaft or crankshaft spacer. You can also use a different crankshaft spacer to make up the difference. I milled the converter in my case
Re: installed powergllide... [Re: coronetville] #978882
04/24/11 02:03 PM
04/24/11 02:03 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I've posted about this on small blocks before. Can't see why they would have done any better a job on BB's. Run a 1/4" mid plate. Make a new crank adapter 1/4" thicker or a 1/4" shim. Put it together and use 1/4" less shims. Worked for me. Then I got tired of chasing shims across the floor and made a starter shim or just tack the shims needed together.
Question though. Does ATI and Reid do a better job with all of this?
Oh and forget buying a midplate for a small block to space the starter as well as the bell. Why? JW put the starter in a different place than MOPAR. Make your own mid plate, problem solved.
Leon
Re: installed powergllide... [Re: Leon441] #978883
04/24/11 08:25 PM
04/24/11 08:25 PM
Wisconsin
MagnumExpress Offline
Wisconsin
I run an ATI SuperCase with ATI Bell. No starter issues at all. No shims required. bolted just like the factory.
#9 in the world. 2006 IHRA Super Rod
2010 IHRA Div.5 Hot Rod Champion
Re: installed powergllide... [Re: MagnumExpress] #978884
04/24/11 09:14 PM
04/24/11 09:14 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Big block or small block with the ATI?
Leon
Re: installed powergllide... [Re: Leon441] #978885
04/24/11 09:43 PM
04/24/11 09:43 PM
Harrisville,PA
GRAYBO Offline
GRAYBO  Offline
Harrisville,PA
Give me a shout when you are wrenching on this thing again. My brother and I both run 440 engines and built custom spacers. You definitly want to use the nose cone. LESS STRESS LESS HEADACHES>>>> Good luck. John EMAIL for my phone.....
Re: installed powergllide... [Re: GRAYBO] #978886
04/25/11 01:46 PM
04/25/11 01:46 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
If you need something made I have a milling machine
Let me know when you go to the track. I plan on going to US-60 fri night if the weather holds.
Re: installed powergllide... [Re: FastmOp] #978887
04/25/11 11:36 PM
04/25/11 11:36 PM
KY
KY
We are heading to Chicago on friday morning for a no prep race. Would like to take my car to the valley the following weekend but the water level isn't looking good.
I think I have everything figured out on the starter issues. I removed the spacer, a few shims and all is well. Car is ready to go! Thanks.
Re: installed powergllide... [Re: juicedcuda] #978888
04/26/11 12:36 AM
04/26/11 12:36 AM
mogadore ohio 44260
mogadore ohio 44260
090 midplate
