installed powergllide...
#978869
04/23/11 02:03 PM
04/23/11 02:03 PM
Posts: 761 KY
juicedcuda
KY
Installed a power glide with JW bell housing behind BB in my 'Cuda. I used the supplied spacer for the snout in the bell housing. When using the spacer you have to use the supplied starter shims obviously to be able to tighten down the two starter bolts. Once my starter snout is all the way in the spacer and the 5 supplied shims are in there, there is still a 1/8" to 3/16" gap between the bell housing and starter flange, so I added additional shims to take up the gap. Now when the starter is engaged there isn't enough gear hitting the teeth on the flywheel. What do I do? And why wouldn't JW supply enough shims to take up the gap the spacer puts the starter out?
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Re: installed powergllide...
[Re: racingblues1426]
#978872
04/23/11 06:38 PM
04/23/11 06:38 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
I`m also using the same set up with a Mopar mini starter sans shims here as well . Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: chryco]
#978873
04/23/11 06:54 PM
04/23/11 06:54 PM
Posts: 2,498 PA
moparacer
PA
I have a 1/4 inch aluminum mid plate with a ultra bell and don't use any shims either.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: juicedcuda]
#978874
04/23/11 11:28 PM
04/23/11 11:28 PM
Posts: 3,427 Dandridge TN
Dabee
Dandridge TN
Remove the snout. You don't need it. I have never been able to get one to fit all the way in the hole in the bell for it. Shim the starter so you have .100 between the stater gear and the ring gear. That will give you full engagement of the gears.
[Re: juicedcuda]
#978876
04/24/11 02:54 AM
04/24/11 02:54 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I am not sure which flywheel and center hub you are using but there are different set ups. There are some where the hub goes onto the crank flange first and the flywheel on top of it. The others mount the flywheel first and hub second. The starter ring gear winds up in a different place when compared. Pictured are various hub adapters. Some worked better when installed first rather than the flywheel. Nearly all required a spacer to pull the starter back from the wheel. In most cases the same size as the midplate.
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#978877
04/24/11 02:55 AM
04/24/11 02:55 AM
HEMIFRED
SOUTH JERSEY
they have come in different thicknesses
[Re: HEMIFRED]
#978878
04/24/11 02:57 AM
04/24/11 02:57 AM
HEMIFRED
SOUTH JERSEY
and various spacers came with them others are home made
[Re: HEMIFRED]
#978880
04/24/11 08:44 AM
04/24/11 08:44 AM
Posts: 976 ontario canada
mac56
ontario canada
As Fred stated sometimes you have to mix and match because of all the possible combinations of mid plates. I had to make my crank adapter but I'm using jw bell and I think it is a tci wheel.If I read your post right it sounds like the starter snout is getting hung up in the pilot hole. Did you dry fit your starter before you put the transmission in? When I fit my starter on the bench the first time it would not engage all the way. The snout and pilot needed to be cleaned up a bit. I can see having to shim the starter to get the right engagement on the ring gear but the starter should go in tight to the bell housing unless there is interference in the pilot hole.
[Re: coronetville]
#978882
04/24/11 02:03 PM
04/24/11 02:03 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I've posted about this on small blocks before. Can't see why they would have done any better a job on BB's. Run a 1/4" mid plate. Make a new crank adapter 1/4" thicker or a 1/4" shim. Put it together and use 1/4" less shims. Worked for me. Then I got tired of chasing shims across the floor and made a starter shim or just tack the shims needed together.
Question though. Does ATI and Reid do a better job with all of this?
Oh and forget buying a midplate for a small block to space the starter as well as the bell. Why? JW put the starter in a different place than MOPAR. Make your own mid plate, problem solved.
Leon
[Re: Leon441]
#978883
04/24/11 08:25 PM
04/24/11 08:25 PM
Posts: 108 Wisconsin
MagnumExpress
Wisconsin
I run an ATI SuperCase with ATI Bell. No starter issues at all. No shims required. bolted just like the factory.
#9 in the world. 2006 IHRA Super Rod 2010 IHRA Div.5 Hot Rod Champion
