Shorter rim screws #977019
04/20/11 02:09 PM
04/20/11 02:09 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Because I can never get a pair of Pheonix tires to hold air, I bought tubes. Problem is the Moroso screws which are 1/4" X 3/4" are too long and I dont want to pop my new tubes. I tried grinding the ends off a couple screws but really need the pointy end to penetrate the bead... even tried pilot holes with the long screw but they wont grab the tire and dont want to strip out the screw hole in the rim.
I am sure I am not the first one to deal with this, what did you guys do?
Re: Shorter rim screws [Re: Scamp451] #977020
04/20/11 02:47 PM
04/20/11 02:47 PM
Central Coast
P
Plumcrazyracing Offline
P
Central Coast
Well, well. So, I am not the only one to have discovered this problem and posted about it. My solution was to use a washer. I had the slicks off and measured the length of the screw on the inside of the rim. Measured the thickness of the bead on my slicks. Found the correct size washer and it has worked well. I tried grinding and filing the screw (didnt work well). bought 5/8 screws but ended up being too short. stripped out my screw holes and had to drill new ones. All trial and error for me. However, bigger slicks have a thicker bead. I found that mickey thompson 29.5 13.5w had a 3/4 inch bead as apposed to the half inch my M&H and Hoosier 29/12/15's had. If the bead is only half inch a typical rim screw will pass through the bead (depending on angle of screw of course).
Use a thin washer with a 3/4 screw! Make sure the washer O.D. is the same as the head of the screw O.D.
Almost forgot, depends on the thickness of your wheel (bead area)too. I have Centerline Warriors. They are a bit thin compared to some others.
When I initially had this problem and inquired about it, everyone at the track responded with the deer in the headlights look!
Steve
Re: Shorter rim screws [Re: Plumcrazyracing] #977021
04/20/11 04:53 PM
04/20/11 04:53 PM
Q
Quicktree Offline
Quicktree  Offline
Q
2 small washers will make them work, been there done that.
Re: Shorter rim screws [Re: Quicktree] #977022
04/20/11 05:05 PM
04/20/11 05:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I had thin steel rims so I used a little washer.
Re: Shorter rim screws [Re: Dodgem] #977023
04/20/11 05:17 PM
04/20/11 05:17 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i use self drilling & tapping Tek screws & install them with the cordless drill. they're just over 1/2" long.
Re: Shorter rim screws [Re: Dodgem] #977024
04/20/11 05:22 PM
04/20/11 05:22 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
This is what I did years ago, I didn't like the screw look in my new wheels so I used long stainless pop rivets, I think 3/16" dia. x 1/2". drilled the rims, put on the tires and drilled the tires. Inserted the rivets. Wore those slicks out and upon removal found that the bead had only moved about 1/4", basicly elongated the holes some. Worked for me.
Re: Shorter rim screws [Re: Scamp451] #977025
04/20/11 10:18 PM
04/20/11 10:18 PM
Central Coast
P
P
Central Coast
I just checked and I ended up using a #10 3/16 washer. Hope that helps.
Steve
Re: Shorter rim screws [Re: Scamp451] #977026
04/20/11 10:38 PM
04/20/11 10:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you drill square into the wheel... should be on
a angle... never had any problems
Re: Shorter rim screws [Re: Plumcrazyracing] #977027
04/20/11 10:50 PM
04/20/11 10:50 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Steve
Yes this does help, thanks Steve. Did you get the washers at a regular home improvment or hardware store? There is always McMaster Carr, Grainger or Fastenal I guess.
These are 28.5 X 10.5, so the bead is probably smaller than what you have. I may have to have some holes touched with a tig and let the screw re-thread it .
Mike- the rims were already drilled, I bought them used. They go in on a pitch, but not quite enough to bury them in the bead completely.
Re: Shorter rim screws [Re: Scamp451] #977028
04/21/11 01:14 AM
04/21/11 01:14 AM
Central Coast
P
P
Central Coast
I went to orchard supply. dont know if you have an orchard supply there but it is just an oversized hardware home and garden store. Your beads are probably right at a 1/2 inch.
Let us know if it works out for you.
Steve
