Re: Shorter rim screws
[Re: Scamp451]
#977020
04/20/11 02:47 PM
04/20/11 02:47 PM
Posts: 184 Central Coast
Plumcrazyracing
Central Coast
Well, well. So, I am not the only one to have discovered this problem and posted about it. My solution was to use a washer. I had the slicks off and measured the length of the screw on the inside of the rim. Measured the thickness of the bead on my slicks. Found the correct size washer and it has worked well. I tried grinding and filing the screw (didnt work well). bought 5/8 screws but ended up being too short. stripped out my screw holes and had to drill new ones. All trial and error for me. However, bigger slicks have a thicker bead. I found that mickey thompson 29.5 13.5w had a 3/4 inch bead as apposed to the half inch my M&H and Hoosier 29/12/15's had. If the bead is only half inch a typical rim screw will pass through the bead (depending on angle of screw of course).
Use a thin washer with a 3/4 screw! Make sure the washer O.D. is the same as the head of the screw O.D.
Almost forgot, depends on the thickness of your wheel (bead area)too. I have Centerline Warriors. They are a bit thin compared to some others.
When I initially had this problem and inquired about it, everyone at the track responded with the deer in the headlights look!
Steve
[Re: Dodgem]
#977024
04/20/11 05:22 PM
04/20/11 05:22 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
This is what I did years ago, I didn't like the screw look in my new wheels so I used long stainless pop rivets, I think 3/16" dia. x 1/2". drilled the rims, put on the tires and drilled the tires. Inserted the rivets. Wore those slicks out and upon removal found that the bead had only moved about 1/4", basicly elongated the holes some. Worked for me.
[Re: Plumcrazyracing]
#977027
04/20/11 10:50 PM
04/20/11 10:50 PM
Posts: 699 Manassas, VA USA
Scamp451
Manassas, VA USA
I just checked and I ended up using a #10 3/16 washer. Hope that helps.
Steve
Yes this does help, thanks Steve. Did you get the washers at a regular home improvment or hardware store? There is always McMaster Carr, Grainger or Fastenal I guess.
These are 28.5 X 10.5, so the bead is probably smaller than what you have. I may have to have some holes touched with a tig and let the screw re-thread it .
Mike- the rims were already drilled, I bought them used. They go in on a pitch, but not quite enough to bury them in the bead completely.
