Whats the going rate for an R3 block? #976391
04/19/11 02:54 PM
04/19/11 02:54 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
This is not a want ad!
I'm going to be building a small block stroker sometime in the near future and want a good foundation. I'd like to stick with 59* and 340 mains. What is a good price for a new block, who's the best to buy from? Thanks
Re: Whats the going rate for an R3 block? [Re: rck850] #976392
04/19/11 10:30 PM
04/19/11 10:30 PM
Oxford, OH
Blue93Dakota Offline
Oxford, OH
Got mine from the local dealer, but here you go.
http://www.jimsautoparts.com/mopar_performance_blocks.htm
May see what Ryan can get for you.
http://www.shadydellspeedshop.com/
93 Dakota Club Cab R3 Turbo Build in progress
Re: Whats the going rate for an R3 block? [Re: Blue93Dakota] #976393
04/19/11 10:58 PM
04/19/11 10:58 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
$3,000 for the block
Then you got to bore it. Just say you want a 4.100 bore. That is .190" worth of boring. EXPENSIVE.
I would not spend that kind of money and still have 59 degree lifters with 1 7/8 lifter spacing unless I was dictated so by class rules. Just My Opinion.
Leon
Re: Whats the going rate for an R3 block? [Re: Leon441] #976394
04/19/11 11:26 PM
04/19/11 11:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Leon
if at all possible go 48*.... I was lucky
when I bought my 48* siamese 9.20 block... it was
new but I got it at the Indy swap meet... I still
had to bore it, cam tunnel 50mm, mains and the cyl
bores.... which they all need... but I only payed
$800 for it
Re: Whats the going rate for an R3 block? [Re: MR_P_BODY] #976395
04/20/11 12:38 AM
04/20/11 12:38 AM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Well I have W5 heads that I'm using. Isn't there a way to use the W5 on a 48*? or do I need to stick with 58. Thanks
Re: Whats the going rate for an R3 block? [Re: rck850] #976396
04/20/11 12:40 AM
04/20/11 12:40 AM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
i got lucky and found one for $1400 new, just keep your eyes out, mines a 48*
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Whats the going rate for an R3 block? [Re: rck850] #976397
04/20/11 01:03 AM
04/20/11 01:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I believe Ryan J (SDSS) has done a set of W-5s for 48*
Re: Whats the going rate for an R3 block? [Re: MR_P_BODY] #976398
04/20/11 01:28 AM
04/20/11 01:28 AM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Lol I've talked to Ryan so many times the last three years he's probably tired of me kicking tires. I'll probably call tomorrow. I got these heads brand new fully ported(by a reputable shop) for a song I can't give them up. I also don't want to blow all I saved on good heads making them work on a 48* block.
Re: Whats the going rate for an R3 block? [Re: rck850] #976399
04/20/11 02:02 AM
04/20/11 02:02 AM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
We have a 48 degree block with W5 heads. Just put them on the mill.
Re: Whats the going rate for an R3 block? [Re: rck850] #976400
04/20/11 05:57 PM
04/20/11 05:57 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
yes ryan can make an 18deg head work on a 48deg block!
Re: Whats the going rate for an R3 block? [Re: fishy340] #976401
04/20/11 05:58 PM
04/20/11 05:58 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
48deg as we speak are in the 2600 range,59deg is more money as we speak
Re: Whats the going rate for an R3 block? [Re: fishy340] #976402
04/20/11 06:16 PM
04/20/11 06:16 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
The pushrods will stand a lot straighter with the 48 degree lifter setup. The only clearancing is in the bottom portion of the intake flange of the head. Otherwise there is actually more room when you go 48 degree.
Leon
Re: Whats the going rate for an R3 block? [Re: Leon441] #976403
04/20/11 06:29 PM
04/20/11 06:29 PM
408Dust Offline
408Dust  Offline
Keep searching the web and you will find them.I have bought two new 59 degree 9.200 blocks, one for 1,000.00 other for 1,500.00.Then save some coin to have them machined.
Re: Whats the going rate for an R3 block? [Re: 408Dust] #976404
04/20/11 07:50 PM
04/20/11 07:50 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
kent ritter just bought our 9.2 59*,sim. block so iknow that he has one,give him a call next week he's out of town this week
