Re: Whats the going rate for an R3 block?
[Re: Blue93Dakota]
#976393
04/19/11 10:58 PM
04/19/11 10:58 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
$3,000 for the block
Then you got to bore it. Just say you want a 4.100 bore. That is .190" worth of boring. EXPENSIVE.
I would not spend that kind of money and still have 59 degree lifters with 1 7/8 lifter spacing unless I was dictated so by class rules. Just My Opinion.
Leon
[Re: Leon441]
#976394
04/19/11 11:26 PM
04/19/11 11:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Leon
if at all possible go 48*.... I was lucky when I bought my 48* siamese 9.20 block... it was new but I got it at the Indy swap meet... I still had to bore it, cam tunnel 50mm, mains and the cyl bores.... which they all need... but I only payed $800 for it
[Re: rck850]
#976396
04/20/11 12:40 AM
04/20/11 12:40 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
i got lucky and found one for $1400 new, just keep your eyes out, mines a 48*
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: rck850]
#976397
04/20/11 01:03 AM
04/20/11 01:03 AM
MR_P_BODY
Well I have W5 heads that I'm using. Isn't there a way to use the W5 on a 48*? or do I need to stick with 58. Thanks
I believe Ryan J (SDSS) has done a set of W-5s for 48*
[Re: rck850]
#976400
04/20/11 05:57 PM
04/20/11 05:57 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
yes ryan can make an 18deg head work on a 48deg block!
[Re: fishy340]
#976402
04/20/11 06:16 PM
04/20/11 06:16 PM
Leon441
Lynchburg, VA
The pushrods will stand a lot straighter with the 48 degree lifter setup. The only clearancing is in the bottom portion of the intake flange of the head. Otherwise there is actually more room when you go 48 degree.
Leon
