Reinstalling 4 speed??
#976281
04/19/11 10:45 AM
04/19/11 10:45 AM
Posts: 776 Penguin Country
moepwr
Penguin Country
I just installed a newceterforce dual friction clutch on my 1969 Roadrunner. The old cluch was abused and over used I installed a bearing style pilot bearing, instead of the normal brass bushing while I was there. Now when attempting to put the tranny back in I am having trouble lining up the input shaft housing with the back of the bell housing. I can get the spines lines up and the tranny slides in up to the bell housing. I cant get it to fall in to the back of the bell housing. Believe me i was twisting it and moving it around but no luck. I have installed the tranny before and realize it can be a fight. I am just not sure if the bearing style pilot bearing is not giving me the same wiggle room. I will be back at it this afternoon. Any advice would be appreciated. Thanks Dean
Re: Reinstalling 4 speed??
[Re: moepwr]
#976291
04/19/11 04:02 PM
04/19/11 04:02 PM
Posts: 8,874 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
the front bearing retainer is against the back of the bell housing just not lining up with the bell housing.
If its in that far the the shaft has to be in the pilot bearing by now.
The disk must not be centered. Hook up all the linkage and have someone depress the clutch while you line up the trans.
Get yourself 2 or 4 LONG bolts of the same size that bolt the trans to the bellhousing. Cut off the heads and file slots in each that will take a screwdriver. Screw them into the bellhousing and use them to both support and align the front of the trans (DO NOT "hang" the whole tranny on them). Once the trans is in replace one at a time with the proper bolts.
[Re: JohnRR]
#976292
04/19/11 04:26 PM
04/19/11 04:26 PM
Posts: 942 Virginia, US
RTDaddy
super street
super street
Virginia, US
It could be possible you have the wrong throw-out bearing, (too long), and you are actually trying to depress the pressure plate fingers as you put the tranny in. I agree with others that if the tranny is in far enough that the bearing retainer is hitting the back of the bell housing, you are in the pilot bushing. Do not ask how I know about the wrong throw our bearing. To check on the throw out bearing, put it in the clutch fork and hold it against the pressure plate fingers, see how close it is to the register hole in the bell housing, or use a small tape line and stick it through the center of the clutch disc and measure to the back of the throw out bearing, then measure back along the input shaft.bearing retainer and see if there is any interference, (like maybe you're close to the "step" where the machining stops on the bearing retainer where the throw out bearing rides). One other thing to check is for a "ridge" on the end of the input shaft that might be hanging on the pilot bushing. You do not want to know how I helped a "friend" find out about that one either. If you used an old input shaft to line up the clutch disc when you bolted down the pressure plate, and having the tranny in as far as you say, I'm not sure I would try the shot of pushing in the clutch to free up the clutch disc, (only as a last resort). If you try that, be ready, sometimes the throw out bearing can bind on the retainer and you will push the tranny back out, and those 833's are heavy. Good luck. "IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
[Re: Grant]
#976296
05/03/11 04:08 PM
05/03/11 04:08 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
thank you for the advice! the bearing collar is the same size as the bellhousing hole I made sure of that, but I will definitely try what you said when I get out of school, thank you!
It's possible the crank is not drilled deep enough , what pilot bearing are you using ? You may need to trim a little off the end of the input shaft .
[Re: JohnRR]
#976297
05/03/11 04:53 PM
05/03/11 04:53 PM
Posts: 9 pa
Grant
pa
[Re: Grant]
#976299
05/03/11 05:58 PM
05/03/11 05:58 PM
JohnRR
U.S.S.A.
just a brass bushing
The one that is driven in the pilot hole in the crank or the new style that fits the converter register ? If the first how did it fit ?
[Re: Grant]
#976303
05/04/11 10:50 AM
05/04/11 10:50 AM
JohnRR
U.S.S.A.
I got it machined to fit in the crank fits snug now
There is your problem , the crank is not machined correctly for the 4 speed application, you have to trim the end of the input shaft because the input shaft is bottoming out in the end of the crank , cut 1/4" off and you should be fine .
[Re: Grant]
#976305
05/05/11 02:35 PM
05/05/11 02:35 PM
JohnRR
U.S.S.A.
okay, so i got it in. i don't know what the problem was but i took it down one more time and went to put it up and it still came to that little gap and i just kept wiggeling it and it finally went in. But now i have another question. I'm 19 and not all sure about welding but know people that know how to. If i were to just silicone and pop rivot the 4 speed hump in would this work?? or do I HAVE to weld it??
That would be ok , I drove a duster around for years with it just loose on the floor, came in handy when the shifter would jam
[Re: Grant]
#976308
05/06/11 09:19 AM
05/06/11 09:19 AM
JohnRR
U.S.S.A.
awesome, thank you.
now i ran into another delima, i tested out the new steering column to see if all of the lights work and i went to check reverse lights but nothing works on reverse any ideas??? i got a new reverse harness from year one and i used a dmm and i'm not getting any voltage at all from the harness. also the turn signals work but when i turn on the headlights they shut off. any idea why???
Maybe you should start a thread about that and state what year and model car you are working on ?
