Re: Reinstalling 4 speed??
[Re: Grant]
#976303
05/04/11 10:50 AM
05/04/11 10:50 AM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
I got it machined to fit in the crank fits snug now
There is your problem , the crank is not machined correctly for the 4 speed application, you have to trim the end of the input shaft because the input shaft is bottoming out in the end of the crank , cut 1/4" off and you should be fine .
[Re: Grant]
#976305
05/05/11 02:35 PM
05/05/11 02:35 PM
JohnRR
U.S.S.A.
okay, so i got it in. i don't know what the problem was but i took it down one more time and went to put it up and it still came to that little gap and i just kept wiggeling it and it finally went in. But now i have another question. I'm 19 and not all sure about welding but know people that know how to. If i were to just silicone and pop rivot the 4 speed hump in would this work?? or do I HAVE to weld it??
That would be ok , I drove a duster around for years with it just loose on the floor, came in handy when the shifter would jam
[Re: Grant]
#976308
05/06/11 09:19 AM
05/06/11 09:19 AM
JohnRR
U.S.S.A.
awesome, thank you.
now i ran into another delima, i tested out the new steering column to see if all of the lights work and i went to check reverse lights but nothing works on reverse any ideas??? i got a new reverse harness from year one and i used a dmm and i'm not getting any voltage at all from the harness. also the turn signals work but when i turn on the headlights they shut off. any idea why???
Maybe you should start a thread about that and state what year and model car you are working on ?
