Reinstalling 4 speed?? #976281
04/19/11 10:45 AM
04/19/11 10:45 AM
Penguin Country
moepwr Offline OP
moepwr  Offline OP
Penguin Country
I just installed a newceterforce dual friction clutch on my 1969 Roadrunner. The old cluch was abused and over used
I installed a bearing style pilot bearing, instead of the normal brass bushing while I was there. Now when attempting to put the tranny back in I am having trouble lining up the input shaft housing with the back of the bell housing. I can get the spines lines up and the tranny slides in up to the bell housing. I cant get it to fall in to the back of the bell housing. Believe me i was twisting it and moving it around but no luck. I have installed the tranny before and realize it can be a fight.
I am just not sure if the bearing style pilot bearing is not giving me the same wiggle room.
I will be back at it this afternoon. Any advice would be appreciated.
Dean
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: Reinstalling 4 speed?? [Re: moepwr] #976282
04/19/11 10:51 AM
04/19/11 10:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The splines of the input shaft might be hitting the bushing since it is now closer to the trans an the one installed in the hollow of the crank. Another thing to try is once you ve it that far try to depress the clutch , either linkage connected and have someone push in the pedal or a pry bar on the fork , if the disc is a little off it might be binding.
The other is if the engine and trans are not factory original to each other you might have too much runout which is being made worse because you have a tighter fitting bearing closer to the bellhousing. I just discovered that the engine and bellhousing are machined as a unit originally so swapping parts can cause a runout issue.
Re: Reinstalling 4 speed?? [Re: JohnRR] #976283
04/19/11 10:57 AM
04/19/11 10:57 AM
Penguin Country
moepwr Offline OP
moepwr  Offline OP
Penguin Country
Good points, thank you.
The tranny and bellhousing are what I had in there previously.
Excuse my ignorance but what do you mean by runout?
Thanks again
Re: Reinstalling 4 speed?? [Re: moepwr] #976284
04/19/11 11:01 AM
04/19/11 11:01 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Runout is the difference in centerlines between the crank and the hole in the bellhousing that locates the trans. The factory bored the main line and the bellhousing when the engine and bellhousing were original machined as a unit bolted together , swap the bellhousing to another engine and there is no guarantee that the trans mission will be located together properly, worn front bearing and hard getting the 2 mated .
Re: Reinstalling 4 speed?? [Re: moepwr] #976285
04/19/11 11:16 AM
04/19/11 11:16 AM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
Like John RR said, except you can eliminate your runout by adjusting your bell housing using offset dowell pins (a necessary step when installing a Tremec). There's a procedure and image in the FSM for measuring runout. It's not hard but is abit time consuming.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Reinstalling 4 speed?? [Re: Hrtbkr] #976286
04/19/11 11:22 AM
04/19/11 11:22 AM
Penguin Country
moepwr Offline OP
moepwr  Offline OP
Penguin Country
Thank you John for the explaination. I will try to measure it, but I think the main "problem" is the new bearing pilot bearing. It just doesnt give me the same wiggle room. I appreciate the advice and will check it. I will let you know how it goes. I will keep checking in for any other ideas.
Re: Reinstalling 4 speed?? [Re: moepwr] #976287
04/19/11 01:06 PM
04/19/11 01:06 PM
I have installed many factory four speeds with new pilot bushings, none of them had much wiggle room when using a spare input shaft to align the clutch disc I would look at the new bearing depth and spline length Is the front bearing retainer going into the bellhousing hole at all or is it stopped before getting that close?
Re: Reinstalling 4 speed?? [Re: moepwr] #976288
04/19/11 01:09 PM
04/19/11 01:09 PM
California
court9155 Offline
court9155  Offline
California
Typically when things go wrong you always look at the last thing you did.......
67 charger
Re: Reinstalling 4 speed?? [Re: Cab_Burge] #976289
04/19/11 02:55 PM
04/19/11 02:55 PM
Penguin Country
moepwr Offline OP
moepwr  Offline OP
Penguin Country
the front bearing retainer is against the back of the bell housing just not lining up with the bell housing.
Re: Reinstalling 4 speed?? [Re: moepwr] #976290
04/19/11 03:59 PM
04/19/11 03:59 PM
Try loosening(don't forget to tighten them up before using )the pressure plate bolts up so you can move the clutch disc with the trans input shaft to see if it is off center. Make sure and check the bellhousing alignment with the crankshaft center also, it may be two different things goofing you up now
Re: Reinstalling 4 speed?? [Re: moepwr] #976291
04/19/11 04:02 PM
04/19/11 04:02 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If its in that far the the shaft has to be in the pilot bearing by now.
The disk must not be centered. Hook up all the linkage and have someone depress the clutch while you line up the trans.
Get yourself 2 or 4 LONG bolts of the same size that bolt the trans to the bellhousing. Cut off the heads and file slots in each that will take a screwdriver. Screw them into the bellhousing and use them to both support and align the front of the trans (DO NOT "hang" the whole tranny on them). Once the trans is in replace one at a time with the proper bolts.
Re: Reinstalling 4 speed?? [Re: JohnRR] #976292
04/19/11 04:26 PM
04/19/11 04:26 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
It could be possible you have the wrong throw-out bearing, (too long), and you are actually trying to depress the pressure plate fingers as you put the tranny in. I agree with others that if the tranny is in far enough that the bearing retainer is hitting the back of the bell housing, you are in the pilot bushing. Do not ask how I know about the wrong throw our bearing. To check on the throw out bearing, put it in the clutch fork and hold it against the pressure plate fingers, see how close it is to the register hole in the bell housing, or use a small tape line and stick it through the center of the clutch disc and measure to the back of the throw out bearing, then measure back along the input shaft.bearing retainer and see if there is any interference, (like maybe you're close to the "step" where the machining stops on the bearing retainer where the throw out bearing rides). One other thing to check is for a "ridge" on the end of the input shaft that might be hanging on the pilot bushing. You do not want to know how I helped a "friend" find out about that one either. If you used an old input shaft to line up the clutch disc when you bolted down the pressure plate, and having the tranny in as far as you say, I'm not sure I would try the shot of pushing in the clutch to free up the clutch disc, (only as a last resort). If you try that, be ready, sometimes the throw out bearing can bind on the retainer and you will push the tranny back out, and those 833's are heavy. Good luck.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: Reinstalling 4 speed?? [Re: RTDaddy] #976293
05/02/11 06:48 PM
05/02/11 06:48 PM
pa
Grant Offline
Grant  Offline
pa
can you guys help me, I am doing a 4 speed conversion on a 70 dart swinger and I went to put the trans up, and it went in fine but there is like an 1/8 gap between bellhousing and trans. everything is aligned I took it down 3-4 times and it still isn't going in all the way, any suggestions please?? I need help. thank you.
Re: Reinstalling 4 speed?? [Re: Grant] #976294
05/02/11 06:54 PM
05/02/11 06:54 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
A few things can cause this... Did you press the pilot bushing in deep enough? Are you sure that the bearing collar on the front of the trans is the same size as the hole in the bell housing?
In some cases, once you get the trans as far in as you have, you can put the trans IN GEAR. Get a pal to wiggle the trans while you try to spin the output shaft either with the drive shaft or a spare yoke. I've had situations where I have messed with something for an hour and one simple move puts me where I wanted to be. Good Luck and welcome to the site!
Re: Reinstalling 4 speed?? [Re: Kern Dog] #976295
05/03/11 02:32 PM
05/03/11 02:32 PM
pa
Grant Offline
Grant  Offline
pa
thank you for the advice! the bearing collar is the same size as the bellhousing hole I made sure of that, but I will definitely try what you said when I get out of school, thank you!
Re: Reinstalling 4 speed?? [Re: Grant] #976296
05/03/11 04:08 PM
05/03/11 04:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's possible the crank is not drilled deep enough , what pilot bearing are you using ? You may need to trim a little off the end of the input shaft .
Re: Reinstalling 4 speed?? [Re: JohnRR] #976297
05/03/11 04:53 PM
05/03/11 04:53 PM
pa
Grant Offline
Grant  Offline
pa
just a brass bushing
Re: Reinstalling 4 speed?? [Re: JohnRR] #976298
05/03/11 05:21 PM
05/03/11 05:21 PM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
I had to do jut that with mine. The machine shop was scared that they would go to deep and I ended up having to trim about 1/8" off for it to set in and have a little play.
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: Reinstalling 4 speed?? [Re: Grant] #976299
05/03/11 05:58 PM
05/03/11 05:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The one that is driven in the pilot hole in the crank or the new style that fits the converter register ? If the first how did it fit ?
Re: Reinstalling 4 speed?? [Re: JohnRR] #976300
05/03/11 06:47 PM
05/03/11 06:47 PM
pa
Grant Offline
Grant  Offline
pa
I got it machined to fit in the crank fits snug now
