At what power point should I get a trans shield?? #974966
04/17/11 02:23 PM
04/17/11 02:23 PM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
My combo is 500HP/540 Ft Lbs... I am running a stock 727 for now. At what point do I look into getting a trans shield or blanket? This is a street driven car for the most part, but I don't want to cut my feet off playing at a stop light or on a backroad!
Re: At what power point should I get a trans shield?? [Re: redmist] #974967
04/17/11 03:07 PM
04/17/11 03:07 PM
Mansfield,Ohio
Brandon70cuda Offline
Mansfield,Ohio
At the point you value your feet more then the cost of the blanket/shield.....
Re: At what power point should I get a trans shield?? [Re: Brandon70cuda] #974968
04/17/11 03:17 PM
04/17/11 03:17 PM
Mooresville, NC
A70Runner Online content
A70Runner  Online Content
Mooresville, NC
I would say now.
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: At what power point should I get a trans shield?? [Re: A70Runner] #974969
04/17/11 03:23 PM
04/17/11 03:23 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
I would say now.
When the cost of your deductible for prosthetic feet surpasses the cost of a shield / blanket, it's time.
Old, tired, and sometimes broke down. Me, not my car...
Re: At what power point should I get a trans shield?? [Re: redmist] #974970
04/17/11 03:32 PM
04/17/11 03:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you dont do stupid stuff in low gear you can get
away without it since your a street car.... BUT why
not put one on
Re: At what power point should I get a trans shield?? [Re: MR_P_BODY] #974971
04/17/11 03:41 PM
04/17/11 03:41 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
not put one on
Humm........ .... Define stupid stuff
Re: At what power point should I get a trans shield?? [Re: emarine01] #974972
04/17/11 04:15 PM
04/17/11 04:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
not put one on
High RPM decell in low or traction and loss of traction
then traction again
Re: At what power point should I get a trans shield?? [Re: MR_P_BODY] #974973
04/17/11 04:32 PM
04/17/11 04:32 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Ill never have a car without one regardless of what power its making........I need my feet to make money in life.....
Mopar Performance
Re: At what power point should I get a trans shield?? [Re: MR_P_BODY] #974974
04/17/11 04:33 PM
04/17/11 04:33 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Well.... that sounds just like the stupid stuff I do My tag has expired on my blanket is that bad?
Re: At what power point should I get a trans shield?? [Re: emarine01] #974975
04/17/11 04:49 PM
04/17/11 04:49 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Does the blanket know?
Re: At what power point should I get a trans shield?? [Re: emarine01] #974976
04/17/11 07:23 PM
04/17/11 07:23 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Bad blanket! BAD BAD blanket!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: At what power point should I get a trans shield?? [Re: astjp2] #974977
04/17/11 09:03 PM
04/17/11 09:03 PM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
Haha!! Ok I will order something up..
Re: At what power point should I get a trans shield?? [Re: redmist] #974978
04/18/11 01:06 AM
04/18/11 01:06 AM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
You should be able to pick an expired date SFI one for almost nothing...I threw one away. If you have ever seen a 727 come apart you would run to the nearest speed shop and buy one.
Re: At what power point should I get a trans shield?? [Re: Brandon70cuda] #974979
04/18/11 04:03 AM
04/18/11 04:03 AM
Australia
Charger VJ RB Offline
Australia
What size/thickness steel is need to stop an exploding TF, obviously thicker than the floor pan but how much
RB XE274H Q-850
Re: At what power point should I get a trans shield?? [Re: Charger VJ RB] #974980
04/18/11 06:37 AM
04/18/11 06:37 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Not a beautiful sight when
she "blows" time to spend
Re: At what power point should I get a trans shield?? [Re: Charger VJ RB] #974981
04/18/11 10:58 AM
04/18/11 10:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Some of the different shields use 1/4" alum(6061-T6)
spaced off the trans
Re: At what power point should I get a trans shield?? [Re: redmist] #974982
04/18/11 11:45 AM
04/18/11 11:45 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I got a Lofgren blanket. when i bought mine you can choose between an SFI or non SFI blanket. the only difference is the tag on it. i bought the non SFI blanket and saved alot of money and it fits good
Re: At what power point should I get a trans shield?? [Re: sixpackgut] #974983
04/18/11 12:19 PM
04/18/11 12:19 PM
Q
Quicktree Offline
Quicktree  Offline
Q
the difference is lofgren was buying RCI blankets(if my memory is correct) cutting them in half and re-stiching them. one had the sfi sticker sewn back on the other didn't. thats what I heard anyway
Re: At what power point should I get a trans shield?? [Re: Quicktree] #974984
04/18/11 01:26 PM
04/18/11 01:26 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
I guess thats possible
Re: At what power point should I get a trans shield?? [Re: hankcrank] #974985
04/18/11 01:39 PM
04/18/11 01:39 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
You talking about a SHIELD ? ... ????
