11 second 440
#974757
04/17/11 01:35 AM
04/17/11 01:35 AM
Posts: 89 moscow mills mo
smracing
moscow mills mo
have a 71 ebody 4 speed 440 6 pack 391 gears looking do build a 11 second driver stroker heads ect?? have 2 1/2 x pipe magna flow exhaust headers under drive pulleys manual disc brakes looking for help on this motor build thanks to all
Re: 11 second 440
[Re: smracing]
#974758
04/17/11 02:18 AM
04/17/11 02:18 AM
Posts: 1,153 Adrian, Mi
pro6pakRR
mopar addict
mopar addict
Adrian, Mi
My 70 road runner,has a stock bore 440,6bbl,with a 500cfm center carb,mopar 557 solid cam,1.6 Crane roller rocker's,eddy heads.A 8in PTC covertor(5000stall)with 4.10 gears and a 28.5/10.5x15 slick.Has run a best of 11.53@118. It weight's 3895.After we put the cage in it,a 590 cam and 4.88 gears it ran a 11.58@98. We had to short of a shock on it with s/s spring's.And I had to lift around half track.The cage weight at lease 200#.
Re: 11 second 440
[Re: pro6pakRR]
#974759
04/17/11 02:33 AM
04/17/11 02:33 AM
smracing
moscow mills mo
thanks more info on the heads out of the box or ported looking to run pump gas 93 octane puling the motor soon looking for any and all help thanks again
Re: 11 second 440
[Re: smracing]
#974760
04/17/11 04:50 AM
04/17/11 04:50 AM
Posts: 2,141 junction city oregon
viperblue72
I personally think with a heavier car as yours, I would guess a 505 on pump gas and some edelbrock rpm heads and around 250@050 or so solid lifter or roller cam and I think you would be there. Porting the heads would help too if low 11s are the goal. There's a big difference between high 11 and low 11s. I don't have any real world experience with the big block quite yet so this is all an educated guess.
Re: 11 second 440
[Re: viperblue72]
#974761
04/17/11 09:17 AM
04/17/11 09:17 AM
Posts: 399 metro detroit
turner
metro detroit
I dont believe your setting your goals very high, I have a 67 A body that weighs 3200 w/me in it, and its old motor (last year) was running 11.50's with no problems. The 440 was a 68 block, 906 heads with small factory valves and slight gasket matching, .557 mopar cam, ductile rockers system, team g intake, 850 holley w/ a proform body, I believe the part # on the trw pistons were L2295s if I remeber correctly, wich were about 10.5 compression I think, on factory rods shifting at 5800rpm. My car has an automatic with a Coan 3500 streetable convertor, and a 8 3/4 w/35 splines and 4:10 gears... Pro parts headers into a full 3 1/2" magnaflow dual exhaust system, the car is a handfull on the street
Re: 11 second 440
[Re: viperblue72]
#974762
04/17/11 09:33 AM
04/17/11 09:33 AM
Posts: 3,897 St. Louis, MO
Blues_Cuda
St. Louis, MO
As a point of reference, here's what can be done while being on a budget and still be completely streetable: '70 Barracuda that runs a cast crank 440 w/ 906 heads, 4.10 gears, 9.5" PTC converter, 850 AED Holley, M1 single plane, .588 Ultradyne solid flat tappet cam, 10.3:1 actual compression w/ Ross flat tops, Hooker Comp headers, TTI 3" X-pipe exhaust, 295/65 drag radials (or 275/60 ET Streets...runs the same) Not sure what the car weighs, but I assume around 3500 w/o driver. Full interior, all steel, heavy Magnum 500's, etc... In 100% street legal trim, runs 11.50's @ 118mph. Ideally, the car has 11.40's in it once I get the rear suspension sorted out. (One of these days...not a big priority honestly...just a fun car that is on the street much more than the strip.) With that said, 'streetable' has a different meaning to every person you ask. It's all in what the person can tolerate I guess. This burnout was a little overboard.
Re: 11 second 440
[Re: gch]
#974766
04/17/11 11:43 AM
04/17/11 11:43 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
IMO,the engine will need usable low rpm power,like good power down to 2,000. With a 4spd.,and god I love`em the approach will not be identical to an auto. 1st issue is getting off the line. Either spin,lug the motor,or hook w/rpm`s and see what goes first-the car or the drivetrain. Your not going to get Automatic type 60fts. without lots of gear 4.88 or more and or a slipper type clutch{exspensive and not street freindly} So you will have to make up some of what you lost down track,which can work because a manual trans. is more efficient than an auto. When I went from auto to stick my MPH. went from 131mph to 135mph at the same E.T. Just sharing my expeirences. Can you do it ABSOLUTELY And it will be a blast to drive!
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 11 second 440
[Re: Cab_Burge]
#974769
04/17/11 04:47 PM
04/17/11 04:47 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I run mid 11's with a mild 440 in my 63 but I agree a stroker is the easiest way to do it. Mine is a .030 over stock stroke 440 with stock crank and rods and KB quench pistons that gives me 10.0 comp and quench with my 906 heads I ported. I use the MP .557 cam and the Holley SD intake with an 850 DP. I run 1-3/4 hedman headers and 3" pipes. It runs fine on 92 pump and has run a best of 11.49 on a great day at 3700 lbs. My normal ets are 11.50's to 11.70's on average days. Whichever you build I would keep it simple and build a flattop piston zero deck eng with closed chamber heads and use a .039 head gasket for good quench. Good luck , Ron
Re: 11 second 440
[Re: Chargerfan68]
#974771
04/18/11 01:48 AM
04/18/11 01:48 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
040 440, 10.5 comp, ported 452s (no flow numbers, but probably 250-260@ .600), M1 intake, 950HP,2 inch Hookers, 259/.550 Comp TL solid, 5k flash converter, 4.30 gear. 3800lbs, 11.3X's. With a 4k vert went 11.49.
Very nice combo on the street and runs find on pump fuel!!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 11 second 440
[Re: smracing]
#974772
04/18/11 03:27 AM
04/18/11 03:27 AM
pro6pakRR
mopar addict
mopar addict
Adrian, Mi
The heads are out of the box.This car has full interor,10 point cage,and is all steel.Now that we have the shock's right it should run in the high 10's low 11's.It has 3 inch flowmasters on it,to the axle.We have driven it on the street.
Re: 11 second 440
[Re: Mr.Yuck]
#974774
04/18/11 11:40 AM
04/18/11 11:40 AM
383man
Balt. Md
My buddy's 70 RR ran 11.80's w/ a 10.5:1 .030 over 440, ported 915 heads (waaay before Eddy's) Stock 6-pack, MP 557, 1 7/8" headers 4 speed 4.10 dana.
Wow thats almost my combo he ran. Nice solid combo. Ron
Re: 11 second 440
[Re: smracing]
#974776
04/19/11 12:59 PM
04/19/11 12:59 PM
Posts: 701 Southern Maryland
preddy
Southern Maryland
My old combination went (in good air) 11.77 @ 115 in my 69 RR. It was a very mild, completely streetable, combination. I used to get almost 15mpg on the highway if I drove it gently. MP 484 hydraulic cam Stock E-heads 440 .030 over - stock lower end 10:1 Six pack with QF metering blocks 3:91s hooker super comps 1 7/8" Its a 4 speed car but I was using a 727 instead. tight 10" converter It ran great for years. I could drive it to the track, race, and drive home if I wanted. It would have been faster and less expensive with a single 4 and a Performer RPM. Eventually, one of the 40+ year old, stock rods failed and that was that...
