11 second 440 #974757
04/17/11 01:35 AM
04/17/11 01:35 AM
moscow mills mo
smracing Offline OP
smracing  Offline OP
moscow mills mo
have a 71 ebody
4 speed 440 6 pack
391 gears
looking do build a 11 second driver
stroker heads ect??
have 2 1/2 x pipe magna flow exhaust
headers
under drive pulleys
manual disc brakes
looking for help on this motor build
thanks to all
Re: 11 second 440 [Re: smracing] #974758
04/17/11 02:18 AM
04/17/11 02:18 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
My 70 road runner,has a stock bore 440,6bbl,with a 500cfm center carb,mopar 557 solid cam,1.6 Crane roller rocker's,eddy heads.A 8in PTC covertor(5000stall)with 4.10 gears and a 28.5/10.5x15 slick.Has run a best of 11.53@118. It weight's 3895.After we put the cage in it,a 590 cam and 4.88 gears it ran a 11.58@98. We had to short of a shock on it with s/s spring's.And I had to lift around half track.The cage weight at lease 200#.
Re: 11 second 440 [Re: pro6pakRR] #974759
04/17/11 02:33 AM
04/17/11 02:33 AM
moscow mills mo
smracing Offline OP
smracing  Offline OP
moscow mills mo
thanks more info on the heads
out of the box or ported
looking to run pump gas 93 octane
puling the motor soon
looking for any and all
help thanks again
Re: 11 second 440 [Re: smracing] #974760
04/17/11 04:50 AM
04/17/11 04:50 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I personally think with a heavier car as yours, I would guess a 505 on pump gas and some edelbrock rpm heads and around 250@050 or so solid lifter or roller cam and I think you would be there. Porting the heads would help too if low 11s are the goal. There's a big difference between high 11 and low 11s. I don't have any real world experience with the big block quite yet so this is all an educated guess.
Re: 11 second 440 [Re: viperblue72] #974761
04/17/11 09:17 AM
04/17/11 09:17 AM
metro detroit
turner Offline
turner  Offline
metro detroit
I dont believe your setting your goals very high, I have a 67 A body that weighs 3200 w/me in it, and its old motor (last year) was running 11.50's with no problems. The 440 was a 68 block, 906 heads with small factory valves and slight gasket matching, .557 mopar cam, ductile rockers system, team g intake, 850 holley w/ a proform body, I believe the part # on the trw pistons were L2295s if I remeber correctly, wich were about 10.5 compression I think, on factory rods shifting at 5800rpm. My car has an automatic with a Coan 3500 streetable convertor, and a 8 3/4 w/35 splines and 4:10 gears... Pro parts headers into a full 3 1/2" magnaflow dual exhaust system, the car is a handfull on the street
Re: 11 second 440 [Re: viperblue72] #974762
04/17/11 09:33 AM
04/17/11 09:33 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
As a point of reference, here's what can be done while being on a budget and still be completely streetable:
'70 Barracuda that runs a cast crank 440 w/ 906 heads, 4.10 gears, 9.5" PTC converter, 850 AED Holley, M1 single plane, .588 Ultradyne solid flat tappet cam, 10.3:1 actual compression w/ Ross flat tops, Hooker Comp headers, TTI 3" X-pipe exhaust, 295/65 drag radials (or 275/60 ET Streets...runs the same)
Not sure what the car weighs, but I assume around 3500 w/o driver. Full interior, all steel, heavy Magnum 500's, etc...
In 100% street legal trim, runs 11.50's @ 118mph. Ideally, the car has 11.40's in it once I get the rear suspension sorted out. (One of these days...not a big priority honestly...just a fun car that is on the street much more than the strip.)
With that said, 'streetable' has a different meaning to every person you ask. It's all in what the person can tolerate I guess.
This burnout was a little overboard.
Re: 11 second 440 [Re: Blues_Cuda] #974763
04/17/11 10:41 AM
04/17/11 10:41 AM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I'm currently running 11.80s in a heavier 71 b-body (RR) with a sixty over, stock stroke 440. Stock six pack intake and carbs. I have out of the box Source Stealth heads and a Comp Cams 550/570 solid cam. Hooker Super Comps and 3 inch TTI exhaust with H pipe and some ancient 3 chamber Flowmasters, no tail pipes. 727 with forward pattern manual valve body and stock slapstick shifter. 9.5 inch 4,000 Dynamic converter. 4.10 gears and old Super Stock springs. I think 11.60s or .50s are still in my combo just waiting to be found.
I know some won't like to hear this and won't agree, but I see the 4 speed transmission as your biggest obstacle to your goals. I used to race a 4 speed car and I'll never do that again. Just can't beat a good converter and manual valve body.
Re: 11 second 440 [Re: pinkduster] #974764
04/17/11 11:00 AM
04/17/11 11:00 AM
Central NC
gch Offline
gch  Offline
Central NC
CNC ported alum heads make your goal easier whether you stroke it or not.
With 3.91's you could be mid to high 11's with a 440 and low 11's with a 496/505.
Figure 10.5-1 compression with alum heads(pump gas friendly).Camshaft recommendations will get you as many answers as replies.
Todays hyd grinds can get it done and solids make it a little easier.Rollers are great but cost to much for me(or I am too tight).
You need to figure out what size motor,which cylinder head,intake manifold,size of headers,and what size carb before you even think about camshafts.
Then you can get a converter made that works with all of the above.
The default 500hp build in the tech archives will probably get you high 11's with a good converter and a chassis that hooks.
Re: 11 second 440 [Re: gch] #974765
04/17/11 11:21 AM
04/17/11 11:21 AM
Central NC
gch Offline
gch  Offline
Central NC
EDIT:
I see it is a 4speed and a six pak so you have that covered.
Re: 11 second 440 [Re: gch] #974766
04/17/11 11:43 AM
04/17/11 11:43 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
IMO,the engine will need usable low rpm power,like good power down to 2,000.
With a 4spd.,and god I love`em the approach will not be identical to an auto.
1st issue is getting off the line.
Either spin,lug the motor,or hook w/rpm`s and see what goes first-the car or the drivetrain.
Your not going to get Automatic type 60fts. without lots of gear 4.88 or more and or a slipper type clutch{exspensive and not street freindly}
So you will have to make up some of what you lost down track,which can work because a manual trans. is more efficient than an auto.
When I went from auto to stick my MPH. went from 131mph to 135mph at the same E.T.
Just sharing my expeirences.
Can you do it ABSOLUTELY
And it will be a blast to drive!
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 11 second 440 [Re: smracing] #974767
04/17/11 12:27 PM
04/17/11 12:27 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Re: 11 second 440 [Re: smracing] #974768
04/17/11 02:20 PM
04/17/11 02:20 PM
Cab_Burge Online work
Cab_Burge  Online Work
have a 71 ebody 4 speed 440 6 pack 391 gears looking do build a 11 second driver stroker heads ect??have 2 1/2 x pipe magna flow exhaustheaders under drive pulleys manual disc brakes looking for help on this motor buildthanks to all
several things needed to accomplish your goals, better(bigger) exhaust system to start with and a good fuel system traction will be a issue also along with longivity on that 8 3/4 once you start to hook it up real well As far as the motor is this is fast as you really want go If not look at building a stroker motor with a decent set of good heads I have a 452 C.I.(stock stroke)440 with a set of ported big valve 906 heads that has ran 11:30 on pump gas corked up in my 3450 lb. Duster, that motor made 512 HP and 545 ft. lbs torque, nothing special in it. 9.4 to 1 compression and so on. PM me if you want specifics and more combinations. I also have a 464 C.I.(440 with a 3.91 stroke) Eddy headed six pak motor that ruyns low elevens and high tens on pump gas in my Duster the 518 C.I. low deck six pak motor ran low tens in my Duster
Re: 11 second 440 [Re: Cab_Burge] #974769
04/17/11 04:47 PM
04/17/11 04:47 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run mid 11's with a mild 440 in my 63 but I agree a stroker is the easiest way to do it. Mine is a .030 over stock stroke 440 with stock crank and rods and KB quench pistons that gives me 10.0 comp and quench with my 906 heads I ported. I use the MP .557 cam and the Holley SD intake with an 850 DP. I run 1-3/4 hedman headers and 3" pipes. It runs fine on 92 pump and has run a best of 11.49 on a great day at 3700 lbs. My normal ets are 11.50's to 11.70's on average days.
Whichever you build I would keep it simple and build a flattop piston zero deck eng with closed chamber heads and use a .039 head gasket for good quench. Good luck , Ron
Re: 11 second 440 [Re: 383man] #974770
04/17/11 09:16 PM
04/17/11 09:16 PM
New York, USA
Chargerfan68 Offline
New York, USA
Very well said Ron. Pretty much same thing here.
/greg.
Re: 11 second 440 [Re: Chargerfan68] #974771
04/18/11 01:48 AM
04/18/11 01:48 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
040 440, 10.5 comp, ported 452s (no flow numbers, but probably 250-260@ .600), M1 intake, 950HP,2 inch Hookers, 259/.550 Comp TL solid, 5k flash converter, 4.30 gear. 3800lbs, 11.3X's. With a 4k vert went 11.49.
Very nice combo on the street and runs find on pump fuel!!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 11 second 440 [Re: smracing] #974772
04/18/11 03:27 AM
04/18/11 03:27 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
help thanks again
The heads are out of the box.This car has full interor,10 point cage,and is all steel.Now that we have the shock's right it should run in the high 10's low 11's.It has 3 inch flowmasters on it,to the axle.We have driven it on the street.
Re: 11 second 440 [Re: smracing] #974773
04/18/11 10:35 AM
04/18/11 10:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
My buddy's 70 RR ran 11.80's w/ a 10.5:1 .030 over 440, ported 915 heads (waaay before Eddy's) Stock 6-pack, MP 557, 1 7/8" headers 4 speed 4.10 dana.
Coming soon!!!!
Re: 11 second 440 [Re: Mr.Yuck] #974774
04/18/11 11:40 AM
04/18/11 11:40 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow thats almost my combo he ran. Nice solid combo. Ron
Re: 11 second 440 [Re: smracing] #974775
04/19/11 10:40 AM
04/19/11 10:40 AM
South Carolina, United States
carolinacuda Offline
My 74 cuda had a bone stock 440 with ol heavy trw2355 pistons. I put on a set of Indy Ez stock port heads, a hughes 576 solid cam, eddy victor Int with demon 850carb, Hooker comp headers with 3' exh. I run 3.91's and i have a 3500 tci stall. I know some of my parts could be improved on and i still manage a 7.25 in 1/8th.(mid 11's) Im convinced that 7.20 or better is in it. This with stock springs and 275/60 M/T ET streets. So i would say mid 11's are very easy with a stock stroke 440. Trick is the heads, cam, carb, stall, gears need to match up.
Re: 11 second 440 [Re: smracing] #974776
04/19/11 12:59 PM
04/19/11 12:59 PM
Southern Maryland
preddy Offline
preddy  Offline
Southern Maryland
My old combination went (in good air) 11.77 @ 115 in my 69 RR. It was a very mild, completely streetable, combination. I used to get almost 15mpg on the highway if I drove it gently.
MP 484 hydraulic cam
Stock E-heads
440 .030 over - stock lower end
10:1
Six pack with QF metering blocks
3:91s
hooker super comps 1 7/8"
Its a 4 speed car but I was using a 727 instead.
tight 10" converter
It ran great for years. I could drive it to the track, race, and drive home if I wanted. It would have been faster and less expensive with a single 4 and a Performer RPM. Eventually, one of the 40+ year old, stock rods failed and that was that...
