Help me read my plugs #974675
04/17/11 12:07 AM
04/17/11 12:07 AM
Cookeville
Chilort Offline OP
Will Work For Mopars
Chilort  Offline OP
Cookeville
After an afternoon of working in the yard I finally found a couple hours to spare before dark. I threw some new Autolite plugs in my 440. These are the Autolite equivalent of the RC12YC Champion.
I'm still trying to make my part throttle ping go away. I played with the fuel quite a bit the last time I worked on it (I don't have much free time these days). I wanted to make sure I wasn't to rich. I upped the jets in the carb quite a bit before giving last time.
In 26 miles of driving I had several full throttle goes from 1st, through 2nd, and let off a bit before 3rd. I never pulled over to read the plugs right after a pull though.
Here's what #4 looked like when I got home (Autolite plug so the base is black, that isn't oil).
P1230002 by chilort, on Flickr
P1230004 by chilort, on Flickr
P1230005 by chilort, on Flickr
Here's the #8 plug:
P1230006 by chilort, on Flickr
P1230007 by chilort, on Flickr
P1230008 by chilort, on Flickr
Thoughts?
Re: Help me read my plugs [Re: Chilort] #974676
04/17/11 12:11 AM
04/17/11 12:11 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I need better pics to see the timing mark on the strap, and I need a shot down the plug....Tough to see anything in those pics. If the discoloration on the strap is right in the one pics, it shows the heat range too hot. Meaning you need a colder plug. Also, reading plugs can only be done at maximum load. You have to shut it off and read them, otherwise all is out the window.
The ignition timing can be checked by looking at the color of the plug’s ground strap and the position of the "blue line" on the strap. The blue line really indicates the point at which the strap has reached annealing temperature of the metal. Further down the strap, the more timing is in the engine....
Ideally, you want this blue line to be just below where the ground strap makes the sharp bend and above the weld. If you advance the ignition too far the blue will disappear off the strap and the strap will pick up rainbow colors (blues and greens)
Re: Help me read my plugs [Re: Dragula] #974677
04/17/11 12:20 AM
04/17/11 12:20 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Good info. I have no clue whatsoever about reading plugs other than the pictures I can find on the internet from a Haynes manual, which my engine builder says are worthless with modern gas . I'll get more tomorrow with my wife's good camera.
Thanks.
Re: Help me read my plugs [Re: Chilort] #974678
04/17/11 12:22 AM
04/17/11 12:22 AM
Dragula Offline
Dragula  Offline
What compression is the engine? The plug range is usually determined by compression....
Re: Help me read my plugs [Re: Dragula] #974679
04/17/11 12:25 AM
04/17/11 12:25 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Around 9.2:1 with Eddy heads. It is a terrible setup. Pistons are 0.100 in the hole. I tried reusing some old slugs that weren't really that worn out (long, long, long story where I was tripping over dollars to pick up dimes).
Re: Help me read my plugs [Re: Chilort] #974680
04/17/11 12:37 AM
04/17/11 12:37 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Part throttle ping can be too much vacuum advance?? did you make sure it's on ported vacuum and dial some back with a 3/32 allan wrench in through the vacuum port on the vacuum canister on the dizzy??
Re: Help me read my plugs [Re: Dodgem] #974681
04/17/11 12:43 AM
04/17/11 12:43 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Been trying to clean up my part throttle ping with no vacuum advance attached.
Engine seems to want a lot of initial (19-20*) and nothing else. ...well, not much else.
One thought was that I wasn't getting enough fuel so I converted my el cheapo 750 Holley to one where I could change the jets on all 4 corners and bumped up the jets a number of sizes.
Been playing with this for a little under a year when I get free time. Mostly just trying to see what folks think the plugs are saying.
Re: Help me read my plugs [Re: Chilort] #974682
04/17/11 12:50 AM
04/17/11 12:50 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
If you have a part-throttle ping AND you are using the vacuum advance, the vacuum canister is adjustable by inserting a 3/32 Allen wrench into the canister (where the hose goes) and turning it one way or another. This may not change the total advance as it adjusts how sensitive the vacuum advance is to the vacuum signal, not the total amount of advance when under a high vacuum signal. You can limit the total amount of vacuum advance by limiting the travel of the arm on the canister.
If using the vacuum advance, try disconnecting it and see if the engine still pings. If not, limit the total vacuum advance (I believe stock is 15 degrees added to total timing (initial + mechanical)).
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Help me read my plugs [Re: Chilort] #974683
04/17/11 09:17 AM
04/17/11 09:17 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
What carb you running now?? does it have a power valve. too low a number on the power valve will not let it work at light throttle acceleration where it is supposed to and it will lean ping.
For stock applications with high in gear vacuum 1/2 is ok 16 to 17 maybe an 8.5
For modified aplications 1.5 to 3 numbers below in gear idle vacuum. Just enough to keep it closed.
So 10 in gear vacuum maybe a 7.5 (or 6.5) 8.5 in gear and a 6.5 should work great. 7 in gear and you want a 5 or 5.5 aas long as it stays closed at idle!
Re: Help me read my plugs [Re: Dodgem] #974684
04/17/11 11:46 AM
04/17/11 11:46 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Holley 750 80508S that I've converted to 4150.
I believe the power valve that is in it is a 6.5.
I have about 10inhg in gear at idle.
I was told at one point that I might need a high flow power valve.
My pinging, being a part throttle deal, happens most when I actually have fairly high engine vacuum (15inhg) and seems to go away at lower vacuum levels (i.e. when I give it more gas).
Re: Help me read my plugs [Re: Chilort] #974685
04/17/11 12:20 PM
04/17/11 12:20 PM
fury4speed Offline
fury4speed  Offline
How many miles on the plugs? there either new or the Enging is running very "lean"
Re: Help me read my plugs [Re: fury4speed] #974686
04/17/11 03:25 PM
04/17/11 03:25 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
They had 26 miles on them when I put the photos up. Now they have about 50 but mostly at idle and cruising around town. I'm about to pull a couple and take some more photos.
Edit: photos (8, 6, 4, 2)
P1230015 by chilort, on Flickr
P1230014 by chilort, on Flickr
P1230011 by chilort, on Flickr
P1230010 by chilort, on Flickr
P1230009 by chilort, on Flickr
Jets are 76 primary and 82 secondary. It came with 70 primary and the equivalent of a 75 secondary.
Engine builder's fuel guy says the plugs should look like you pulled them out of the box and you have to look for bits of aluminum to check for detonation.
Re: Help me read my plugs [Re: Chilort] #974687
04/18/11 11:27 AM
04/18/11 11:27 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Bigger squirter nozzles and a high flow PV should help.
Is it set to squirt at the slightest movement of throttle??
It may also need a more aggressive pump cam.
http://www.summitracing.com/search/?keyword=accelerator%20pump%20cams&dds=1
nozzels
http://www.summitracing.com/search/?keyword=accelerator%20nozzles&dds=1
Re: Help me read my plugs [Re: Dodgem] #974688
04/18/11 01:05 PM
04/18/11 01:05 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
It already has a 37 squirter.
I have a box of pump cams but it already has one of the most aggressive pump cams.
If I went with a high flow power valve what would you recommend?
Re: Help me read my plugs [Re: Chilort] #974689
04/18/11 01:41 PM
04/18/11 01:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
hears a 6.5
http://www.summitracing.com/parts/HLY-125-165/
you may want to try a 8.5
http://www.summitracing.com/parts/HLY-125-185/
as long as your in gear vacuum is 10 it will stay closed at idle and tip in much easier
I once used a dual 10.5/5.5 on a 600 holly vac on a mild 318 and that solved my light throttle ping. course my in gear vacuum was 13??
you may have to drill the passages out a bit behind the power valve in the metering block
or the metering block from a 750 may work better if you can fine one to fit!
http://books.google.ca/books?id=6JIHWWW5...DOyF04qhPy1svNM
http://books.google.ca/books?id=oVZrJgUA...igJW0PgYVHppCb4
http://www.bob2000.com/carb.htm
http://www.clubcobra.com/forums/holley-tuning/101183-how-modify-your-holley-power-valve-circuit.html
lots of stuff to read out there I have a holley book somewhere i bought 20 years ago has been invaluable maybe I should update! LOL!
http://www.amazon.com/Holley-Carburetors-Design-Dave-Emanuel/dp/1884089283/ref=pd_sim_b_2
http://www.summitracing.com/parts/SAD-SA08/
Re: Help me read my plugs [Re: Chilort] #974690
04/19/11 12:51 AM
04/19/11 12:51 AM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
I just had this same problem and solved it with a bunch of help from the guys here. This is a link to the thread https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: Help me read my plugs [Re: Boise Chall] #974691
04/21/11 11:38 PM
04/21/11 11:38 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I realize that the power valves are cheap and I live 30 miles away from a Summit outlet. But I don't see how a power valve is going to fix my issue. While my idle vacuum in gear is 10inhg, the vacuum where I first start to experience the ping is still around 15inhg or so. At this point, even an 8.5 valve shouldn't be contributing fuel. Right?
Re: Help me read my plugs [Re: Chilort] #974692
04/22/11 09:56 AM
04/22/11 09:56 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
But when you give it throttle vacuum drops quickly. this is when you are in transision and not enough air is moving past the ventures to give the richness it needs to accelerate. the power valve supplies that fuel needed for the transision no fuel lean = lean ping
Check out the links in my April 18th post and or buy a book!
Re: Help me read my plugs [Re: Dodgem] #974693
04/22/11 12:19 PM
04/22/11 12:19 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I understand what a lean ping is. What I am saying is that I get ping holding steady at 12-18inhg. I have a vacuum gauge and I can look at it with my two eyes while pulling a slight grade and hear with my two ears what sounds like detonation. No grade, no problem. Full throttle, no problem. But at 12-18inhg, after the reading I have done in some of the links you posted, I don't see how a power valve is going to help.
I can see why people get frustrated with Holley carbs. "Wet flowed to work right out of the box" my fat a55. Maybe on a Chevy 350.
Re: Help me read my plugs [Re: Chilort] #974694
04/22/11 05:03 PM
04/22/11 05:03 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
EVERY carb needs tuned to each engine.
Even if you change an intake or timing or exhaust, you still may need some changes.
My 'guess' is that it has too much initial timing and the off idle curcuit is too lean. This is befor the main curcuit is flowing ( the jets).
Do you know the idle transition-fuel sizes? Or even the idle air jets sizes? This is where you will find the problem.
