Cuda MSD Question #973794
04/15/11 03:03 PM
04/15/11 03:03 PM
Texas
Y
Yesdogjr Offline OP
Yesdogjr  Offline OP
Y
Texas
Ok this may be a stupid question but I have to ask.
My motor is going back in this weekend and I choose to use an MSD Distributor and a MSD 6AL box.
My question is will I still need to hook up the original ballast and orange Controller or were those only used by the original distributor?
Re: Cuda MSD Question [Re: Yesdogjr] #973795
04/15/11 03:10 PM
04/15/11 03:10 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
No, With the MSD box, the origial ecu and ballast is no longer used.
I pulled the 2 connectors for the ballast ouf of the bulkhead conector, tied them as one and used it as my key on voltage for the MSD box.
Re: Cuda MSD Question [Re: gtx6970] #973796
04/15/11 03:16 PM
04/15/11 03:16 PM
Texas
Y
Yesdogjr Offline OP
Yesdogjr  Offline OP
Y
Texas
Thanks!
I call it a controller but I guess I should really call it the Voltage regulator. Still same answer?
Re: Cuda MSD Question [Re: Yesdogjr] #973797
04/16/11 11:01 AM
04/16/11 11:01 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
This is the charging system voltage regulator , and yes it stays as original.
Re: Cuda MSD Question [Re: gtx6970] #973798
04/16/11 01:29 PM
04/16/11 01:29 PM
Texas
Y
Yesdogjr Offline OP
Yesdogjr  Offline OP
Y
Texas
Wow Thanks! Im glad I stopped by here before going to the shop. I was going to leave it off thanks again.
Re: Cuda MSD Question [Re: Yesdogjr] #973799
04/16/11 11:05 PM
04/16/11 11:05 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
This may help.
Sorry it didn't attach, anyway it was the instruction manual. PM me your e-mail address if you need it, I'll e-mail it to you.
6588271-MSD6wiring.pdf (118 downloads)
Careful, your character's showing!
