426 max wedge heads on a 440? #968016
04/06/11 07:32 PM
04/06/11 07:32 PM
Ontario,Canada
Muskiehunter51 Offline OP
Ontario,Canada
I have 1964 max wedge heads fully rebuilt (1500.00$ later), will they fit a 1969 440 block? If so any idea what I should do to make it street capable?
---->> Head # 2402286 ( there is another number 6-27 along with some letters)
---->> Intake # 2465185 ( turns out the intake manifold is from a 64 max wedge, it was 7 years ago when i bought them and i never ran the numbers)
Re: 426 max wedge heads on a 440? [Re: Muskiehunter51] #968017
04/06/11 07:40 PM
04/06/11 07:40 PM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
What type of intake and exhaust system do you have for these heads ?
Re: 426 max wedge heads on a 440? [Re: Muskiehunter51] #968018
04/06/11 07:51 PM
04/06/11 07:51 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
yes, they will fit. You don't have to do anything special for them, except like the other question, what intake are you going to use, or what would you like to use?
Re: 426 max wedge heads on a 440? [Re: IcorkSOAK] #968019
04/06/11 08:04 PM
04/06/11 08:04 PM
Ontario,Canada
Ontario,Canada
none at the moment, any suggestions?
Re: 426 max wedge heads on a 440? [Re: Muskiehunter51] #968020
04/06/11 08:07 PM
04/06/11 08:07 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
x ram
I am truckless..
Re: 426 max wedge heads on a 440? [Re: 340SHORTY] #968021
04/06/11 08:16 PM
04/06/11 08:16 PM
Ontario,Canada
Ontario,Canada
Oh sorry i ment that for the exhaust reply, I have a 1969 4 barrel intake. it was used by dodge in nascar its been ported and polished apparently its been combines with these exact heads before.
Re: 426 max wedge heads on a 440? [Re: IcorkSOAK] #968022
04/06/11 08:28 PM
04/06/11 08:28 PM
Ontario,Canada
Ontario,Canada
4bbl intake that was used by dodge in nascar in 69, no exhaust yet any ideas
Re: 426 max wedge heads on a 440? [Re: Muskiehunter51] #968023
04/06/11 08:37 PM
04/06/11 08:37 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Dodge didn't use the Max Wedge in 1969.
The 426 Hemi was used in NASCAR with the "bathtub" 4 bbl intake manifold.
If you are thinking 1964 MAX WEDGE, with a 4 bbl intake, then you would be correct.
This is the MAX WEDGE intake that you must have.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 426 max wedge heads on a 440? [Re: Muskiehunter51] #968024
04/06/11 08:46 PM
04/06/11 08:46 PM
AndyF Offline
AndyF  Offline
They should fit on a 440 block. Might want to double check clearance for the exhaust valve but it should work. If you don't want to run a cross ram then get a Mopar Performance 337 intake. The 337 fits the MW heads and has a cast valley plate to seal up the engine. It is a 4150 style intake so you can run a Holley carb.
Re: 426 max wedge heads on a 440? [Re: hemi71x] #968025
04/06/11 08:47 PM
04/06/11 08:47 PM
Ontario,Canada
Ontario,Canada
I know they didnt use the 426 MW, they did use 440s which is what i have and from what i understand this will line up with the 426 heads but please correct me if im wrong, im only 22. Building a 1972 dodge challenger
Re: 426 max wedge heads on a 440? [Re: Muskiehunter51] #968026
04/06/11 08:52 PM
04/06/11 08:52 PM
hemi71x Offline
hemi71x  Offline
440's were not allowed in NASCAR.
They were too large in the cubic inch displacement.
426 was 7 litre displacement, and that was the limit.
Your learning. Lot's of folks on this board will stear you in the right direction with their replys.
Re: 426 max wedge heads on a 440? [Re: hemi71x] #968027
04/06/11 09:08 PM
04/06/11 09:08 PM
Ontario,Canada
Ontario,Canada
i thought the superbirds and charger daytonas raced nascar with both 426hemi and 440s 4bbl and six bbl from all the reading ive done. Anyways i just checked the numbers on the intake it reads 2465185
Re: 426 max wedge heads on a 440? [Re: Muskiehunter51] #968028
04/06/11 09:18 PM
04/06/11 09:18 PM
hemi71x Offline
hemi71x  Offline
No, only the 426 Hemi at NASCAR.
Don't know what you've been reading about that.
Re: 426 max wedge heads on a 440? [Re: Muskiehunter51] #968029
04/06/11 09:30 PM
04/06/11 09:30 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
Honestly .... I would SELL what you have and buy something with better potential street-manners. A Xram and these heads are not a good street combo ....ESPECIALLY with 5$ a gallon premium fuel.
You could sell JUST THE HEADS ...and buy some nice alum ones ... and still have $$$ left-over to totally complete the project ..
Re: 426 max wedge heads on a 440? [Re: hemi71x] #968030
04/06/11 09:54 PM
04/06/11 09:54 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
To "clarify" EVEN further, the 440 "std port" type heads were allowed in NASCAR, depending on
length of track, gearing, chassis wedge and stagger rates, etc. The 426 MAX Wedge heads were used
also under the same considerations as above. The 426 MW did see NASCAR action mid '63 to about mid 64' (HEMI's arrival) A 440
block "could" of been used for the 7-litre NASCAR
apps., IF they were "sleeved" to the 4.255 bore size. As said before, the 440 displacement SIZE was not allowed. Max cid size limit was 7-litres or 430 cubes for the "ol' schoolers" AS far as the "winged warriors" their engine sizes
went from 7-litres (426 HEMI) to 5-litre penalty(305 cid-destroked 340 engine/4.04 bore by 2.96 stroke crank), due to wind-cheating advantages of the Daytona and Superbird on the LONGER superspeedways. After 71' the 426's were all of the standard wedge head variety (non MW, they were never made beyond 64'). Check on this!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 426 max wedge heads on a 440? [Re: IcorkSOAK] #968031
04/06/11 10:12 PM
04/06/11 10:12 PM
Desert Tracker
Desert Tracker
Or... hold on to them for a LATER "harder hitting"
strip project!!
Re: 426 max wedge heads on a 440? [Re: Muskiehunter51] #968032
04/07/11 10:15 AM
04/07/11 10:15 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
What you have are actually '62-3 max wedge heads. The '64 MW used the 518 castings.
Re: 426 max wedge heads on a 440? [Re: 70440+6bbl] #968033
04/07/11 01:40 PM
04/07/11 01:40 PM
Ontario,Canada
Ontario,Canada
will they fit the 440/ any idea what they may be worth?
Re: 426 max wedge heads on a 440? [Re: Muskiehunter51] #968034
04/07/11 06:50 PM
04/07/11 06:50 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
Yes they will fit a 440 fine. If they are nice heads with some good recent work done to them .... they should be worth maybe 25 huN.
Re: 426 max wedge heads on a 440? [Re: Muskiehunter51] #968035
04/07/11 07:54 PM
04/07/11 07:54 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
They fit and work well.I have the same heads on a 440,cross ram,MW manifolds.Runs strong.
