426 max wedge heads on a 440?
#968016
04/06/11 08:32 PM
04/06/11 08:32 PM
Posts: 9 Ontario,Canada
Muskiehunter51
Ontario,Canada
I have 1964 max wedge heads fully rebuilt (1500.00$ later), will they fit a 1969 440 block? If so any idea what I should do to make it street capable?
---->> Head # 2402286 ( there is another number 6-27 along with some letters) ---->> Intake # 2465185 ( turns out the intake manifold is from a 64 max wedge, it was 7 years ago when i bought them and i never ran the numbers)
Re: 426 max wedge heads on a 440?
[Re: hemi71x]
#968027
04/06/11 10:08 PM
04/06/11 10:08 PM
Muskiehunter51
Ontario,Canada
i thought the superbirds and charger daytonas raced nascar with both 426hemi and 440s 4bbl and six bbl from all the reading ive done. Anyways i just checked the numbers on the intake it reads 2465185
[Re: Muskiehunter51]
#968029
04/06/11 10:30 PM
04/06/11 10:30 PM
Posts: 30,464 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
none at the moment, any suggestions?
Honestly .... I would SELL what you have and buy something with better potential street-manners. A Xram and these heads are not a good street combo ....ESPECIALLY with 5$ a gallon premium fuel.
You could sell JUST THE HEADS ...and buy some nice alum ones ... and still have $$$ left-over to totally complete the project ..
[Re: hemi71x]
#968030
04/06/11 10:54 PM
04/06/11 10:54 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
I know they didnt use the 426 MW, they did use 440s which is what i have and from what i understand this will line up with the 426 heads but please correct me if im wrong, im only 22. Building a 1972 dodge challenger
440's were not allowed in NASCAR. They were too large in the cubic inch displacement. 426 was 7 litre displacement, and that was the limit.
Your learning. Lot's of folks on this board will stear you in the right direction with their replys.
To "clarify" EVEN further, the 440 "std port" type heads were allowed in NASCAR, depending on length of track, gearing, chassis wedge and stagger rates, etc. The 426 MAX Wedge heads were used also under the same considerations as above. The 426 MW did see NASCAR action mid '63 to about mid 64' (HEMI's arrival) A 440 block "could" of been used for the 7-litre NASCAR apps., IF they were "sleeved" to the 4.255 bore size. As said before, the 440 displacement SIZE was not allowed. Max cid size limit was 7-litres or 430 cubes for the "ol' schoolers" AS far as the "winged warriors" their engine sizes went from 7-litres (426 HEMI) to 5-litre penalty(305 cid-destroked 340 engine/4.04 bore by 2.96 stroke crank), due to wind-cheating advantages of the Daytona and Superbird on the LONGER superspeedways. After 71' the 426's were all of the standard wedge head variety (non MW, they were never made beyond 64'). Check on this!!
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
#968032
04/07/11 11:15 AM
04/07/11 11:15 AM
Posts: 5,268 NY
70440+6bbl
NY
What you have are actually '62-3 max wedge heads. The '64 MW used the 518 castings.
#968035
04/07/11 08:54 PM
04/07/11 08:54 PM
Posts: 1,281 WI
wannadrag
WI
will they fit the 440/ any idea what they may be worth?
They fit and work well.I have the same heads on a 440,cross ram,MW manifolds.Runs strong.
