New motor loud valves... #965583
04/04/11 03:09 AM
04/04/11 03:09 AM
San Diego
64dartsb Offline OP
64dartsb  Offline OP
San Diego
I just got the cam reground by crower. The cam card says set the lash to .18 intake and exhaust. I did that and they still sound kinda loud when it heats up. I just drove the car like 6 blocks on the slow hill in front of my house. The motor also has lash caps on it to correct the roller rocker/valve tip geometry. Could that be making the extra noise? I'm thinking I should adjust the valves tighter but how tight?
if your dreaming of your car then it's your dream car....
Re: New motor loud valves... [Re: 64dartsb] #965584
04/04/11 03:20 AM
04/04/11 03:20 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
need more info, aluminum heads? Did you run the valves hot or cold? Cam specs?
Re: New motor loud valves... [Re: 1_WILD_RT] #965585
04/04/11 03:35 AM
04/04/11 03:35 AM
San Diego
64dartsb Offline OP
64dartsb  Offline OP
San Diego
steel heads. I let the motor warm up. It was in park and the water temp was prolly around 210 the rockers were hot when I set it to .18 but I haven't driven it around then adjusted right after. This was my first little drive in it.
I don't have the cam card with me, I will have it tomorrow. But it's .522 107 lobe center installed straight up. solid crower lifters
Re: New motor loud valves... [Re: 64dartsb] #965586
04/04/11 03:54 AM
04/04/11 03:54 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
If those lash-caps are loosey ... that SURE COULD be the reason for the noise.
Re: New motor loud valves... [Re: 64dartsb] #965587
04/04/11 08:02 AM
04/04/11 08:02 AM
Delray beach, Florida
P
Performance Only Offline
P
did you set them to .18 as you posted, or .018? .18 would make enough noise to wake the dead.
machine shop owner and engine builder
Re: New motor loud valves... [Re: 64dartsb] #965588
04/04/11 10:50 AM
04/04/11 10:50 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
How are you setting them up?
kasey
Re: New motor loud valves... [Re: 64dartsb] #965589
04/04/11 11:40 AM
04/04/11 11:40 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm kind of going thru the same thing. New set-up solid roller (588) w/ stage VI heads. I set mine at .012/.012 cold. I seem to be having some noise up top I'm not confortable with. I re-check lash yesterday and it was fine. I think maybe the rockers and hitting the valve covers?? They are H/S and are reallt FAT.
Coming soon!!!!
Re: New motor loud valves... [Re: Mr.Yuck] #965590
04/04/11 11:47 AM
04/04/11 11:47 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
put your hand on the cover while it's running , if they are hitting you will feel it .
Re: New motor loud valves... [Re: JohnRR] #965591
04/04/11 11:51 AM
04/04/11 11:51 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah when i get back from Tennessee Friday I will. I did notice some marks inside the valve covers...up front and at the back.
Re: New motor loud valves... [Re: Mr.Yuck] #965592
04/04/11 11:58 AM
04/04/11 11:58 AM
That's probably what you are hearing then.
Re: New motor loud valves... [Re: JohnRR] #965593
04/04/11 03:39 PM
04/04/11 03:39 PM
San Diego
64dartsb Offline OP
64dartsb  Offline OP
San Diego
I checked them today. They're set at .018. I'm gonna have an experienced ear listen to it today....
Re: New motor loud valves... [Re: 64dartsb] #965594
04/04/11 03:44 PM
04/04/11 03:44 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
If you are running the small block Mopar Performance cast aluminum valve covers,the rockers may be hitting the baffles inside the covers. I had this issue recently with a small block with stock rocker arms.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: New motor loud valves... [Re: JohnRR] #965595
04/04/11 05:33 PM
04/04/11 05:33 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
double up on the gaskets, and it should clear up the noises. glue two together, with rtv and allow them to dry, then install as you normally would. be sure you DON'T over tighten them when you reinstall them.
