Re: New motor loud valves...
[Re: 64dartsb]
#965584
04/04/11 03:20 AM
04/04/11 03:20 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
need more info, aluminum heads? Did you run the valves hot or cold? Cam specs?
[Re: 1_WILD_RT]
#965585
04/04/11 03:35 AM
04/04/11 03:35 AM
Posts: 363 San Diego
64dartsb
San Diego
steel heads. I let the motor warm up. It was in park and the water temp was prolly around 210 the rockers were hot when I set it to .18 but I haven't driven it around then adjusted right after. This was my first little drive in it.
I don't have the cam card with me, I will have it tomorrow. But it's .522 107 lobe center installed straight up. solid crower lifters
if your dreaming of your car then it's your dream car....
[Re: Mr.Yuck]
#965590
04/04/11 11:47 AM
04/04/11 11:47 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I'm kind of going thru the same thing. New set-up solid roller (588) w/ stage VI heads. I set mine at .012/.012 cold. I seem to be having some noise up top I'm not confortable with. I re-check lash yesterday and it was fine. I think maybe the rockers and hitting the valve covers?? They are H/S and are reallt FAT.
put your hand on the cover while it's running , if they are hitting you will feel it .
[Re: JohnRR]
#965591
04/04/11 11:51 AM
04/04/11 11:51 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yeah when i get back from Tennessee Friday I will. I did notice some marks inside the valve covers...up front and at the back.
[Re: JohnRR]
#965593
04/04/11 03:39 PM
04/04/11 03:39 PM
64dartsb
San Diego
I checked them today. They're set at .018. I'm gonna have an experienced ear listen to it today....
[Re: 64dartsb]
#965594
04/04/11 03:44 PM
04/04/11 03:44 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
If you are running the small block Mopar Performance cast aluminum valve covers,the rockers may be hitting the baffles inside the covers. I had this issue recently with a small block with stock rocker arms.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
