What will it run? 440 #963679
04/01/11 01:25 PM
04/01/11 01:25 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Just bought some parts to go with a 440 in my Valiant and I'm just wondering what I can expect ET wise. The build is going to be pretty simple .060 over 440, stock 906 heads, probably a 509 cam or a mild solid, old Tm-7 or some other single plane and a 850 holley. I may end up going with a glide but what ever trans I go with will have a 9.5in converter and I'll be running a 3.55 gear(all I have besides a 5.38) and a 28" tire. The car weighs 3100 with me and fuel with the smallblock. I want to run atleast 7.50's in the 1/8th
Re: What will it run? 440 [Re: SLOW67] #963680
04/01/11 01:52 PM
04/01/11 01:52 PM
My 3450 lb. Duster with a sinmilar 440 ran low 12.s(12.01 to 12.13) in the 1/4 years ago on pump gas corked up I don't remember the 1/8 mile times, sorry
Re: What will it run? 440 [Re: Cab_Burge] #963681
04/01/11 02:11 PM
04/01/11 02:11 PM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
7.90 or so with that gear.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: What will it run? 440 [Re: moparmxz] #963682
04/01/11 02:40 PM
04/01/11 02:40 PM
louisiana
71440dart Offline
71440dart  Offline
louisiana
right now my dart with a 30 over 440, 906 heads, .557 solid and a 9.5 inch 4500 converter with 3.90 gears and a 28 inch tall tires runs 7.28 8th and 11.43 in the quarter.i have no idea how much it weighs, it has full interior and i weigh about 180.
71 dodge dart race car,440/727 best so far: 11.23 @119 74 plymoth duster, 408SB/727
Re: What will it run? 440 [Re: 71440dart] #963683
04/01/11 02:51 PM
04/01/11 02:51 PM
Pa
W
W7_Scamp Offline
W7_Scamp  Offline
W
Pa
11.70's in the quarter if i had to take a stab at it
Re: What will it run? 440 [Re: SLOW67] #963684
04/01/11 03:33 PM
04/01/11 03:33 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
I would guestimate 12.50 but hopefully better dont know what that translates in eighth mile
Re: What will it run? 440 [Re: W7_Scamp] #963685
04/01/11 04:08 PM
04/01/11 04:08 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Thats about what i would say, I ran 6.9s/7.0s/10.90s/11.0s depending on the weather at 3100 race weight & 4.10 gears/28" slicks with a similar set-up, now it was a low-deck 451/stock 906s/XE284H/750dp/M1 single/9.73.1 comp./PTC 9.5" 4400 stall shifting at 5600.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: What will it run? 440 [Re: SLOW67] #963686
04/01/11 04:14 PM
04/01/11 04:14 PM
Central NC
gch Offline
gch  Offline
Central NC
Consider running an rpm intake or the Holley street dominator for a single plane.THe small solid may work better on the low end with the 3.55 gears.All that may be a moot point depending on your stall speed.
Re: What will it run? 440 [Re: gch] #963687
04/01/11 06:55 PM
04/01/11 06:55 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
low 12ish with that cam
Re: What will it run? 440 [Re: moparmxz] #963688
04/01/11 07:12 PM
04/01/11 07:12 PM
ky
68roadrunner Offline
ky
that will be real close, use the 5.38 and a 5000rpm stall and you will get close to a 7.50. 727 only
Re: What will it run? 440 [Re: 68roadrunner] #963689
04/01/11 07:45 PM
04/01/11 07:45 PM
ill
dennismopar73 Offline
ill
ive seen low 11s out of combo like that
Re: What will it run? 440 [Re: SLOW67] #963690
04/01/11 08:02 PM
04/01/11 08:02 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
With a bone stock 440 and vert in that car it should run 12.50,s
With the 3.55 gear Id want around a 4000 stall vert and 10.0 comp. Id use either a RPM or SD single plane. With traction that could be good for 11.20,s or so.
My old 9.7 484 MP stock vert street combo @ 3320# ran 12.40,s @ 113 MPH with street tires. With slicks it ran 11.75.
Add in your 9.5 vert and less weight, even with the 3.55 gear you should do better then that, IMO
For reference, 7.65/1/8 = 12.00 --7.50/1/8 = 11.75
Re: What will it run? 440 [Re: Sport440] #963691
04/01/11 08:37 PM
04/01/11 08:37 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
3100 lbs + 440/stock heads/509' cam + 9.5" (4000 rpm) converter/3.55 gear = 7.65 range 1/8 mile
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: What will it run? 440 [Re: HYPER8oSoNic] #963692
04/01/11 08:48 PM
04/01/11 08:48 PM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
His post claimed 3100 with the small block,i would add at least 150 for the pig block.
Re: What will it run? 440 [Re: moparmxz] #963693
04/01/11 10:35 PM
04/01/11 10:35 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I saw that and tried to adjust my guestimates for it.
I also saw your numbers What kind of combo do you have going on?
Re: What will it run? 440 [Re: Sport440] #963694
04/01/11 11:56 PM
04/01/11 11:56 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
I'd be happy if I could get 7.80's out of it with the 3.55's. I plan on going to a 4.10 or 4.56 after I get the engine in the car and everything worked out....I don't want to spend all my money before then lol
Re: What will it run? 440 [Re: SLOW67] #963695
04/02/11 12:43 AM
04/02/11 12:43 AM
OH, USA
Torred Offline
Torred  Offline
OH, USA
You should get the 7.80 with the 3.55, maybe even a little better.
Re: What will it run? 440 [Re: Torred] #963696
04/02/11 12:59 AM
04/02/11 12:59 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The build is almost identical to mine. I have a .030 906 headed 440 with the .557 solid cam and the Holley SD intake with an 850. My 63 weighs 3700 with me and I use a Dynamic 9.5 converter and 4.30's with 30" tall tires. 11.49 best and 7.28 best in the 1/8. I say you should hit 11.70's which is about 7.50's in the 1/8. Good luck , Ron
Re: What will it run? 440 [Re: fishy340] #963697
04/02/11 01:21 AM
04/02/11 01:21 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Your joking right? .
Re: What will it run? 440 [Re: joedust451] #963698
04/02/11 02:36 AM
04/02/11 02:36 AM
Circleville, Ohio
E
Evil67 Offline
Evil67  Offline
E
Circleville, Ohio
It has the potential to run 11.50s.....the rest is up to you!!!
Former Username - 71Cuda
Current Ride: 1967 Dart - 340
