I need advice on pinion snubber alternatives???? #963237
03/31/11 06:08 PM
03/31/11 06:08 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
My 69 RR has a cut down Dana (Dr Diff) and it doesn't have provisions for a snubber, not just the holes but the raised pads too. So my MP snubber won't work. It definately needs it because I have had the driveshaft/ yoke hit the tunnel once already. So what cheap alternatives to a pinion snubber are there? I know cal tracs will work, but thats not in the budget. Will the kicker shocks work? I thought about welding in some reinforcing plate on the floor and bolting the rubber bumpstop on there. Any ideas would be greatly appreciated because I'd really like to be able to powershift and lay down some rubber in my bird.
Re: I need advice on pinion snubber alternatives???? [Re: NV69B7RR] #963238
03/31/11 06:52 PM
03/31/11 06:52 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Stiff springs and the right shocks.I have the 3800# SS springs on my car and Rancho 9000 series adjustable shocks I don't use a snubber and I don't have any issues.
Gus
64 Plymouth Savoy
Dana 60
Re: I need advice on pinion snubber alternatives???? [Re: NV69B7RR] #963239
03/31/11 06:53 PM
03/31/11 06:53 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
pinion snubber alternatives ....
TWO WORDS ......
PROPER springs ...
Re: I need advice on pinion snubber alternatives???? [Re: dOc …] #963240
03/31/11 07:08 PM
03/31/11 07:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
FWIW, My Mustang had the inverted snubber setup you are thinking of. Probably cheaper than Cal Tracs or new springs.
One other thing to consider is clamping the leafs on the front half of the spring together. YOu can clamp as many as you need to stffen the front segment and control spring wrap up, assuming you don't need more than all the leafs clamped to control it. That's old school but it works to an extent.
Don't be the exception.
Re: I need advice on pinion snubber alternatives???? [Re: Supercuda] #963241
03/31/11 10:24 PM
03/31/11 10:24 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
The snubber hanging down from the floorpan is'nt a bad idea...Also, I remember someone posted a pic of a plate that bolted to the front reinforcing webbing on each side of the pinion {which required drilling some holes for the bolts} with a bracket bridging over the pinion with the snubber on it...
