Re: I need advice on pinion snubber alternatives????
[Re: NV69B7RR]
#963238
03/31/11 06:52 PM
03/31/11 06:52 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Stiff springs and the right shocks.I have the 3800# SS springs on my car and Rancho 9000 series adjustable shocks ![](/ubbthreads/images/graemlins/thumbs.gif) I don't use a snubber and I don't have any issues. Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: NV69B7RR]
#963239
03/31/11 06:53 PM
03/31/11 06:53 PM
Posts: 30,493 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
pinion snubber alternatives .... TWO WORDS ...... PROPER springs ... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: dOc …]
#963240
03/31/11 07:08 PM
03/31/11 07:08 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
FWIW, My Mustang had the inverted snubber setup you are thinking of. Probably cheaper than Cal Tracs or new springs.
One other thing to consider is clamping the leafs on the front half of the spring together. YOu can clamp as many as you need to stffen the front segment and control spring wrap up, assuming you don't need more than all the leafs clamped to control it. That's old school but it works to an extent.
