Re: budget turbo ?
[Re: strokin73cuda]
#962175
03/30/11 11:59 AM
03/30/11 11:59 AM
Posts: 2,255 IL
furious70
IL
Lots of old Detroit turbos will work ok on a 440, look for a tv75 or tv81. The compressor wheels and exhaust housings can vary a lot in them, so you kind of have to get lucky. You would not want an exhaust housing with the 1.6 ratio (the ration is usually stamped on the inside of the turbine inlet) They will all be T6 large frame turbos.
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: budget turbo ?
[Re: strokin73cuda]
#962185
03/31/11 12:59 AM
03/31/11 12:59 AM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
I just bought the jegs kit for $119 and a set of $50 flanges off ebay and a few 3" mandrel bends and several 3" V-band clamps.. I used a chop saw but a band saw would have been easier.
Equal length is not really an issue with a turbo!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: budget turbo ?
[Re: pishta]
#962187
03/31/11 10:23 AM
03/31/11 10:23 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
could you do something like this w/ a BB?
Sure, but were would you put it???
How about cut up mud bog or tractor pull headers, come straight up, bend them forward, flange them, mount turbo(s) and run a Spectre dual inlet hat, symetrical install. Have 1/2 of the snails come out of the hood like a shaker and watch them glow at night!
well ya'd have to bend it around the k-frame, unless you went with a new tubular unit.
Re: budget turbo ?
[Re: furious70]
#962190
04/01/11 06:41 PM
04/01/11 06:41 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You cheated by using truck/van manifolds. The passenger car manifolds will not work upside down. That was the first thing I tried when I went turbo.
