budget turbo ? #962174
03/29/11 11:40 PM
03/29/11 11:40 PM
northeast texas
strokin73cuda Offline OP
northeast texas
I have a friend that is a diesel mech.Is there a stock diesel engine turbo (or twin set)that will work good on a stock 73 440 build ? Wich one? And what is possible to get out of it? Thanks trying to get back on an old project.
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: budget turbo ? [Re: strokin73cuda] #962175
03/30/11 11:59 AM
03/30/11 11:59 AM
IL
furious70 Offline
furious70  Offline
IL
Lots of old Detroit turbos will work ok on a 440, look for a tv75 or tv81. The compressor wheels and exhaust housings can vary a lot in them, so you kind of have to get lucky. You would not want an exhaust housing with the 1.6 ratio (the ration is usually stamped on the inside of the turbine inlet) They will all be T6 large frame turbos.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: budget turbo ? [Re: strokin73cuda] #962176
03/30/11 12:11 PM
03/30/11 12:11 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The turbos are the cheap part. You going to flip the mani's or make custom headers?
Coming soon!!!!
Re: budget turbo ? [Re: Mr.Yuck] #962177
03/30/11 02:31 PM
03/30/11 02:31 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You can't flip B/RB manifolds. They will block the spark plug holes. If you put them on the wrong side the steering box and driver's engine mount are in the way.
- Stu Harmon
Re: budget turbo ? [Re: feets] #962178
03/30/11 02:40 PM
03/30/11 02:40 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
ahhhh, even the lo-po logs? what about flipping shorty headers?
Re: budget turbo ? [Re: Mr.Yuck] #962179
03/30/11 02:54 PM
03/30/11 02:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
could you do something like this w/ a BB?
Re: budget turbo ? [Re: Mr.Yuck] #962180
03/30/11 09:00 PM
03/30/11 09:00 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Sure, but were would you put it???
How about cut up mud bog or tractor pull headers, come straight up, bend them forward, flange them, mount turbo(s) and run a Spectre dual inlet hat, symetrical install. Have 1/2 of the snails come out of the hood like a shaker and watch them glow at night!
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: budget turbo ? [Re: pishta] #962181
03/30/11 11:54 PM
03/30/11 11:54 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
Sanderson headers makes block huggers for the big block. I have often thought of going that way instead of stock manifolds.
http://www.sandersonheaders.com/Sanderson-DD2-Chrysler-383-440-V8-Blockhugger-Header-Set.html
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: budget turbo ? [Re: Mr.Yuck] #962182
03/31/11 12:50 AM
03/31/11 12:50 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
B engine in a 68 A-body,
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: budget turbo ? [Re: CUUDAK] #962183
03/31/11 12:52 AM
03/31/11 12:52 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Re: budget turbo ? [Re: CW25] #962184
03/31/11 12:52 AM
03/31/11 12:52 AM
northeast texas
northeast texas
I have a set of cheap unused headers to cut up and some fabing skills for the build, just not the knowhow at this point. I am asking your guys opinions to get a jump start on the build. I will buy a new tubo if need be butt I know there has to be a cheaper way and still wouldn't know wich new turbo to buy or how to properly plan to fab the headers without someones help. So what turbos should I look for? Or maybe I should have posted What are your stock 440 turbo combos ?
Re: budget turbo ? [Re: strokin73cuda] #962185
03/31/11 12:59 AM
03/31/11 12:59 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
I just bought the jegs kit for $119 and a set of $50 flanges off ebay and a few 3" mandrel bends and several 3" V-band clamps.. I used a chop saw but a band saw would have been easier.
Equal length is not really an issue with a turbo!
Re: budget turbo ? [Re: strokin73cuda] #962186
03/31/11 01:05 AM
03/31/11 01:05 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Several ideas here,
http://www.theturboforums.com/smf/index.php?board=21.0
Re: budget turbo ? [Re: pishta] #962187
03/31/11 10:23 AM
03/31/11 10:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
well ya'd have to bend it around the k-frame, unless you went with a new tubular unit.
Re: budget turbo ? [Re: strokin73cuda] #962188
03/31/11 04:58 PM
03/31/11 04:58 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I went with twins but you might be able to wrap this into a single.
- Stu Harmon
Re: budget turbo ? [Re: feets] #962189
04/01/11 04:05 PM
04/01/11 04:05 PM
IL
furious70 Offline
furious70  Offline
IL
I'm turning my manifolds upside down
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: budget turbo ? [Re: furious70] #962190
04/01/11 06:41 PM
04/01/11 06:41 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You cheated by using truck/van manifolds. The passenger car manifolds will not work upside down. That was the first thing I tried when I went turbo.
- Stu Harmon
