Syn Blend after cam break in?? #960579
03/27/11 11:11 PM
03/27/11 11:11 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Is it ok to use a syn blend right after cam break in?
Ive got Brad Penn, but dont know if the rings will like a blend.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Syn Blend after cam break in?? [Re: Von] #960580
03/27/11 11:21 PM
03/27/11 11:21 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Many new vehicles come factory fill with Fully Synthetic motor oil... Not a problem with piston ring sealing.
CompSyn
Re: Syn Blend after cam break in?? [Re: Von] #960581
03/27/11 11:35 PM
03/27/11 11:35 PM
I believe so & if youre getting ready for a breakin might read this (5 minutes) "breakin secrets" at www.mototuneusa.com
Re: Syn Blend after cam break in?? [Re: Von] #960582
03/28/11 11:47 AM
03/28/11 11:47 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Does anybody think buying an off the shelf "blend" makes any sense vs justing mixing syn and dino together, and besides, why is the blend % never stated? What are they hiding? Kinda like buying mid octane (89?)fuel IMO.
Re: Syn Blend after cam break in?? [Re: jcc] #960583
03/28/11 01:35 PM
03/28/11 01:35 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
They only have to blend in 5% to legaly call it a blend and the average is 10 to 15%
I always blend my own then you know you get 50/50
Re: Syn Blend after cam break in?? [Re: CompSyn] #960584
03/28/11 06:22 PM
03/28/11 06:22 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
CompSyn
Total Seal told me 1500-2000 miles or 25-30 hard passes before going to a blend type oil.
Re: Syn Blend after cam break in?? [Re: Von] #960585
03/28/11 06:32 PM
03/28/11 06:32 PM
MO
cdp Offline
cdp  Offline
MO
I was recommended Brad Penn Racing oil by a well known racer/engine builder for all my oil changes.
Re: Syn Blend after cam break in?? [Re: Von] #960586
03/28/11 10:24 PM
03/28/11 10:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
CompSyn
Plazma rings are not stock do as they say!
Re: Syn Blend after cam break in?? [Re: cdp] #960587
03/28/11 11:21 PM
03/28/11 11:21 PM
. 4X yearly. Synthetics temp a person to go w the extended changes & it's the accum contaminates that are the prob, My
Re: Syn Blend after cam break in?? [Re: Von] #960588
03/29/11 12:23 PM
03/29/11 12:23 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
Is the engine a flat tappet or a roller cam? I don't see any problem if it's a roller, if it's
If it's a flat tappet I think the question becomes whether to stick with a high zinc oil or additive after beak in or once the cam is broken in if you can use off the shelf oil from the parts store either syn, blend or pure dinosaur.
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Syn Blend after cam break in?? [Re: finadk] #960589
03/29/11 03:04 PM
03/29/11 03:04 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
quote]
Doesnt matter if its roller, flat, etc.....rings are what Im worried about.
Ive got plenty of zinc additive...no problem with that.
Dwayne advised against blend for a few miles/passes. So, I mixed some old stock Rotella and a specially blended dyno oil.
Re: Syn Blend after cam break in?? [Re: finadk] #960590
03/29/11 03:07 PM
03/29/11 03:07 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Scott
By the way, you STILL have to run a quality oil or add zinc after the cam is broke in. Spring pressure is spring pressure........
I cant follow the line of reasoning that says once the cam is broke in I dont need zinc anymore.
Re: Syn Blend after cam break in?? [Re: Von] #960591
03/29/11 07:19 PM
03/29/11 07:19 PM
No syntheteics for me in the hot rods, okay in the dailey drivers except my Cummins T.D.
