Syn Blend after cam break in??
#960579
03/27/11 11:11 PM
03/27/11 11:11 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Is it ok to use a syn blend right after cam break in? Ive got Brad Penn, but dont know if the rings will like a blend.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Syn Blend after cam break in??
[Re: Von]
#960582
03/28/11 11:47 AM
03/28/11 11:47 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Does anybody think buying an off the shelf "blend" makes any sense vs justing mixing syn and dino together, and besides, why is the blend % never stated? What are they hiding? Kinda like buying mid octane (89?)fuel IMO.
[Re: jcc]
#960583
03/28/11 01:35 PM
03/28/11 01:35 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
They only have to blend in 5% to legaly call it a blend and the average is 10 to 15% I always blend my own then you know you get 50/50
[Re: CompSyn]
#960584
03/28/11 06:22 PM
03/28/11 06:22 PM
Von
NE Oklahoma
Many new vehicles come factory fill with Fully Synthetic motor oil... Not a problem with piston ring sealing.
CompSyn
Total Seal told me 1500-2000 miles or 25-30 hard passes before going to a blend type oil.
[Re: Von]
#960586
03/28/11 10:24 PM
03/28/11 10:24 PM
Dodgem
Ontario, Canada
CompSyn
Plazma rings are not stock do as they say!
[Re: Von]
#960588
03/29/11 12:23 PM
03/29/11 12:23 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
Is the engine a flat tappet or a roller cam? I don't see any problem if it's a roller, if it's If it's a flat tappet I think the question becomes whether to stick with a high zinc oil or additive after beak in or once the cam is broken in if you can use off the shelf oil from the parts store either syn, blend or pure dinosaur. Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: finadk]
#960589
03/29/11 03:04 PM
03/29/11 03:04 PM
Von
NE Oklahoma
Is the engine a flat tappet or a roller cam? I don't see any problem if it's a roller, if it's quote]
Doesnt matter if its roller, flat, etc.....rings are what Im worried about.
Ive got plenty of zinc additive...no problem with that.
Dwayne advised against blend for a few miles/passes. So, I mixed some old stock Rotella and a specially blended dyno oil.
[Re: finadk]
#960590
03/29/11 03:07 PM
03/29/11 03:07 PM
Von
NE Oklahoma
By the way, you STILL have to run a quality oil or add zinc after the cam is broke in. Spring pressure is spring pressure........
I cant follow the line of reasoning that says once the cam is broke in I dont need zinc anymore.
