Fuel Pressure Regulator #958475
03/25/11 02:10 PM
03/25/11 02:10 PM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
I have a 73 Cuda and want to install a return style fuel pressue regulator. Where would I connect the return line to the fuel tank? My sending unit only has 1 line. Is there more than 1 vent tube I could use?
Re: Fuel Pressure Regulator [Re: wtucker] #958476
03/25/11 03:02 PM
03/25/11 03:02 PM
Winnipeg, MB, Canada
71Plym Offline
71Plym  Offline
My sending unit had a small (1/4" ?) tube that I removed and opened up for a return line. Regardless, you can drill a hole in the sending unit next to the pickup line and install the return line.
Re: Fuel Pressure Regulator [Re: 71Plym] #958477
03/25/11 11:34 PM
03/25/11 11:34 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
Just so i am thinking right, the regulator has 1 inlet, 1 outlet, and another outlet on the bottom for fuel return, right?
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Fuel Pressure Regulator [Re: rattler] #958478
03/26/11 01:36 PM
03/26/11 01:36 PM
Probally wrong one inlet, two outlets(Holley carbs ) and one return What brand are you thinking of using? I have several two outlets and several four port outlets, one with a return output Inlet on the bottom, outlets and returns on the top. I like to use the bypass from the pump instead of adding another fuel line from the tank to the regulator and taking another risk of leaks and fires
Re: Fuel Pressure Regulator [Re: Cab_Burge] #958479
03/27/11 10:26 AM
03/27/11 10:26 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I looked at an old one in the shop and saw that the inlet is on the bottom and both ends were outlets. So, can i use one of the outlets for a return line?If not, how is the best way to run a return to tank? The pump only has inlet and outlet.
