Re: Fuel Pressure Regulator
[Re: 71Plym]
#958477
03/25/11 11:34 PM
03/25/11 11:34 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
Just so i am thinking right, the regulator has 1 inlet, 1 outlet, and another outlet on the bottom for fuel return, right?
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: rattler]
#958478
03/26/11 01:36 PM
03/26/11 01:36 PM
Posts: 43,198 Bend,OR USA
Cab_Burge
Probally wrong one inlet, two outlets(Holley carbs ) and one return What brand are you thinking of using? I have several two outlets and several four port outlets, one with a return output Inlet on the bottom, outlets and returns on the top. I like to use the bypass from the pump instead of adding another fuel line from the tank to the regulator and taking another risk of leaks and fires
[Re: Cab_Burge]
#958479
03/27/11 10:26 AM
03/27/11 10:26 AM
rattler
Crofton, Ky.
I looked at an old one in the shop and saw that the inlet is on the bottom and both ends were outlets. So, can i use one of the outlets for a return line?If not, how is the best way to run a return to tank? The pump only has inlet and outlet.
