pushrod length #954504
03/20/11 02:01 PM
03/20/11 02:01 PM
Amherst,NY
challengermike Offline OP
Amherst,NY
If you go with a .018 thinner headgasket could you still get away with the same pushrods on a hydraulic lifter engine?
Re: pushrod length [Re: challengermike] #954505
03/20/11 02:26 PM
03/20/11 02:26 PM
Yes, you're OK
Re: pushrod length [Re: RapidRobert] #954506
03/20/11 02:45 PM
03/20/11 02:45 PM
Amherst,NY
Amherst,NY
i figured it would be but i thought i should just ask though.
Re: pushrod length [Re: challengermike] #954507
03/20/11 02:57 PM
03/20/11 02:57 PM
I totally agree, every detail is worth checking, being meticulous adds up will get you to the finish line faster than the next who isn't
Re: pushrod length [Re: challengermike] #954508
03/20/11 03:53 PM
03/20/11 03:53 PM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
which head gaskets will you be using?
Re: pushrod length [Re: lokalik] #954509
03/20/11 04:52 PM
03/20/11 04:52 PM
Amherst,NY
Amherst,NY
Its for a buick grand national engine.but its still the same setup as the mopars with non adjustable rockers.i asked a few questions over at the buicks sites but it seems to be a ghost town over there,lol.
Re: pushrod length [Re: challengermike] #954510
03/20/11 04:57 PM
03/20/11 04:57 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
DEPENDS , how much are the lifters already compressed from any head and/or block cutting that has already been done , assuming you have stock length pushrods.
Re: pushrod length [Re: JohnRR] #954511
03/20/11 05:05 PM
03/20/11 05:05 PM
Amherst,NY
Amherst,NY
Its all stock now.i just wanted to bump the compression up alittle and since im pulling the heads to have them redone.
Re: pushrod length [Re: challengermike] #954512
03/20/11 05:07 PM
03/20/11 05:07 PM
JohnRR Offline
JohnRR  Offline
Before you pull the rockers with the intake off see if you can see how much the lifters cups are preloaded.
Re: pushrod length [Re: JohnRR] #954513
03/20/11 05:11 PM
03/20/11 05:11 PM
Amherst,NY
Amherst,NY
sounds like a good idea,i will look and see.
Re: pushrod length [Re: challengermike] #954514
03/20/11 05:21 PM
03/20/11 05:21 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
usually you will not have a problem with a change like that. Hydraulic lifters have a lot of forgiveness built in. I would be very surprised if you were to have a problem.
