Re: pushrod length
[Re: challengermike]
#954507
03/20/11 02:57 PM
03/20/11 02:57 PM
RapidRobert
I totally agree, every detail is worth checking, being meticulous adds up will get you to the finish line faster than the next who isn't
Re: pushrod length
#954508
03/20/11 03:53 PM
03/20/11 03:53 PM
Posts: 797 arizona, usa
lokalik
arizona, usa
If you go with a .018 thinner headgasket could you still get away with the same pushrods on a hydraulic lifter engine?
which head gaskets will you be using?
Re: pushrod length
#954510
03/20/11 04:57 PM
03/20/11 04:57 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
DEPENDS , how much are the lifters already compressed from any head and/or block cutting that has already been done , assuming you have stock length pushrods.
Re: pushrod length
#954512
03/20/11 05:07 PM
03/20/11 05:07 PM
JohnRR
Its all stock now.i just wanted to bump the compression up alittle and since im pulling the heads to have them redone.
Before you pull the rockers with the intake off see if you can see how much the lifters cups are preloaded.
