Powerglide in ebody? #954232
03/20/11 01:17 AM
03/20/11 01:17 AM
KY
juicedcuda Offline OP
KY
Anyone have any pics or suggestions on the trans crossmember for putting a Powerglide behind a bbm in an ebody?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Powerglide in ebody? [Re: juicedcuda] #954233
03/20/11 01:28 AM
03/20/11 01:28 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I have more pics in my desk top but it's not hooked up right now. this is a decent picture to give some idea. I know where no rear mount has also been used without any problems ..
home of the
Sox and Martin Hemi Duster
Re: Powerglide in ebody? [Re: HEMIFRED] #954234
03/20/11 01:35 AM
03/20/11 01:35 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Fred, do you recall how far ahead the trans mount is from the original cross member mount? or is your engine set back?
Re: Powerglide in ebody? [Re: HEMIFRED] #954235
03/20/11 01:38 AM
03/20/11 01:38 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You can actually use the stock crossmember piece if you want. With a little fab work it is a piece of cake. Remove the stock mount, and adapt the PG mount to the stock crossmember. IIRC you are within 1-1.5" of it aligning. Done it a few times for folks.
Re: Powerglide in ebody? [Re: rowin4] #954236
03/20/11 01:39 AM
03/20/11 01:39 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I'll get you some pictures tomorrow afternoon of my '64 Dodge. I am using a stock cross member with a Powerglide. I know it's not an E-Body, but it might give you an idea.
Re: Powerglide in ebody? [Re: sixpakdodge] #954237
03/20/11 03:03 AM
03/20/11 03:03 AM
KY
KY
From the rough measurement I took, seems the Powerglide mount is 4" closer to the front of the car than the 727.
Re: Powerglide in ebody? [Re: Al_Alguire] #954238
03/20/11 11:29 AM
03/20/11 11:29 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Worked for me , really slick .
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Powerglide in ebody? [Re: juicedcuda] #954239
03/20/11 11:31 AM
03/20/11 11:31 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Measure it again
Re: Powerglide in ebody? [Re: Al_Alguire] #954240
03/20/11 11:39 AM
03/20/11 11:39 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
with Al my bud did that with his duster works like a charm
Re: Powerglide in ebody? [Re: chryco] #954241
03/20/11 12:08 PM
03/20/11 12:08 PM
rowin4 Offline
rowin4  Offline
Measure it again
So, what measurement data do you have? my original cross member has been modified, so I know that the powerglide mount is about 4" different from a Doug Nash.
Re: Powerglide in ebody? [Re: rowin4] #954242
03/20/11 12:47 PM
03/20/11 12:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I think you need to keep in mind that the stock crossmember has a stock mount that is involved also. The mount is forward facing in the crossmember which put the actual mounts fairly close together.
Do you have the stock mount? If so you can see what I am talking about. It is pretty simple to fab a mount for the PG using the stock crossmember. Just get a PG mount and from there a little steel plate and some cutting and welding and you will be thee in no time.
Sorry I dont have any pictures of it, never thought about it.
Re: Powerglide in ebody? [Re: fishy340] #954243
03/20/11 12:50 PM
03/20/11 12:50 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Another here!
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Powerglide in ebody? [Re: Al_Alguire] #954244
03/20/11 01:17 PM
03/20/11 01:17 PM
Out West
408strokerdart Offline
Out West
This is exactly how mine was originally done. worked out nice. Here's a pic.
Re: Powerglide in ebody? [Re: 408strokerdart] #954245
03/20/11 02:20 PM
03/20/11 02:20 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
The only pic I have , hope it helps
