Powerglide in ebody?
#954232
03/20/11 01:17 AM
03/20/11 01:17 AM
Posts: 761 KY
juicedcuda
KY
Anyone have any pics or suggestions on the trans crossmember for putting a Powerglide behind a bbm in an ebody?
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Re: Powerglide in ebody?
[Re: HEMIFRED]
#954235
03/20/11 01:38 AM
03/20/11 01:38 AM
Posts: 19,369 Las Vegas
Al_Alguire
Las Vegas
You can actually use the stock crossmember piece if you want. With a little fab work it is a piece of cake. Remove the stock mount, and adapt the PG mount to the stock crossmember. IIRC you are within 1-1.5" of it aligning. Done it a few times for folks.
[Re: sixpakdodge]
#954237
03/20/11 03:03 AM
03/20/11 03:03 AM
Posts: 761 KY
juicedcuda
KY
From the rough measurement I took, seems the Powerglide mount is 4" closer to the front of the car than the 727.
1970 Plymouth 'Cuda
1973 Gold Duster
[Re: Al_Alguire]
#954240
03/20/11 11:39 AM
03/20/11 11:39 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
with Al my bud did that with his duster works like a charm
[Re: chryco]
#954241
03/20/11 12:08 PM
03/20/11 12:08 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Measure it again
So, what measurement data do you have? my original cross member has been modified, so I know that the powerglide mount is about 4" different from a Doug Nash.
[Re: rowin4]
#954242
03/20/11 12:47 PM
03/20/11 12:47 PM
Al_Alguire
Las Vegas
I think you need to keep in mind that the stock crossmember has a stock mount that is involved also. The mount is forward facing in the crossmember which put the actual mounts fairly close together.
Do you have the stock mount? If so you can see what I am talking about. It is pretty simple to fab a mount for the PG using the stock crossmember. Just get a PG mount and from there a little steel plate and some cutting and welding and you will be thee in no time.
Sorry I dont have any pictures of it, never thought about it.
[Re: Al_Alguire]
#954244
03/20/11 01:17 PM
03/20/11 01:17 PM
Posts: 3,456 Out West
408strokerdart
Out West
This is exactly how mine was originally done. worked out nice. Here's a pic.
