Road Race Milodon Pan #952601
03/17/11 03:45 PM
03/17/11 03:45 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Has anyone tried one of these in a big block A body? The pan is a Milodon 31580. I have smashed the deep sump pan for the last time, I hope....
Re: Road Race Milodon Pan [Re: marvo451] #952602
03/17/11 09:22 PM
03/17/11 09:22 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I'd like to know this too.
Nautilus Racing-
Re: Road Race Milodon Pan [Re: marvo451] #952603
03/18/11 12:07 AM
03/18/11 12:07 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I have pics of one installed in an A-body with DC type BB spool K-member.
It is Mike Mosely's 68 Barracuda out of Texas.
It's a spool type K-member. Those don't have the pan width clearance like the original big block biscuit motor mount K's have. So you probably will not have to modify an orginal BB A-body K frame as much as the one pictured below. Or might not need to modify at all.
The notch we made developing the new small block stock height pro-touring/road race pan was to fit the spool type 73-76 A-body K-memmbers. Very similar deal to the big block DC spool mount K-members. The big block and small block Milodon road race sump is the same width/basic stamping. Just the big block one is a little longer.
Do these pics help??
Re: Road Race Milodon Pan [Re: autoxcuda] #952604
03/18/11 09:10 AM
03/18/11 09:10 AM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Thanks, that does help. My original Direct Connection big block K-member has been moved forward one inch, so it might fit with no changes. Now I just hope the drag link doesn't interfere in the rear. The motor is in on a motor plate with the motor mounts removed.
Re: Road Race Milodon Pan [Re: marvo451] #952605
03/18/11 01:16 PM
03/18/11 01:16 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The drag could very much be an issue with the motor moved back 1". I'd guess a good chance of it.
Re: Road Race Milodon Pan [Re: autoxcuda] #952606
03/18/11 01:45 PM
03/18/11 01:45 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Looks like I wasn't very clear. The motor is in stock location, but the suspension and K-member are forward one inch along with the drag link.
Re: Road Race Milodon Pan [Re: marvo451] #952607
03/18/11 03:09 PM
03/18/11 03:09 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Still drag link it 1" closer to pan, correct? The back of the Milodon pan is almost where a stock pan is. If you run a stock pan with your setup does the drag/centerlink hit the drain plug when at full turn?
You may be able to cheat with the www.firmfeel.com longer pitman/idler arms. But they may be too long for your headers. Even though when you go to full turn the pitman and idler would come very close (probably hit) to the back side angle of the pan.
Re: Road Race Milodon Pan [Re: autoxcuda] #952608
03/18/11 03:13 PM
03/18/11 03:13 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
I've never run a stock pan in the car. It has the Milodon with a drag link hole in it and has since the early 80's
Re: Road Race Milodon Pan [Re: marvo451] #952609
03/18/11 03:28 PM
03/18/11 03:28 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Probably will have to do some fabricating to get that pan to fit. It's a race car. The motor placement of your car has been changed to it's all educated guesses at this point.
Maybe the longer pitman/idler would help. They are not cheap. But I doubt it with the sweep of the arms to pan side clearance.
Might just have to cut the sump off and move it 1" forward.
