Re: Road Race Milodon Pan
[Re: marvo451]
#952602
03/17/11 09:22 PM
03/17/11 09:22 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I'd like to know this too.
[Re: marvo451]
#952605
03/18/11 01:16 PM
03/18/11 01:16 PM
Posts: 27,453 So Cal
autoxcuda
So Cal
Thanks, that does help. My original Direct Connection big block K-member has been moved forward one inch, so it might fit with no changes. Now I just hope the drag link doesn't interfere in the rear. The motor is in on a motor plate with the motor mounts removed.
The drag could very much be an issue with the motor moved back 1". I'd guess a good chance of it.
[Re: marvo451]
#952607
03/18/11 03:09 PM
03/18/11 03:09 PM
autoxcuda
So Cal
Looks like I wasn't very clear. The motor is in stock location, but the suspension and K-member are forward one inch along with the drag link.
Still drag link it 1" closer to pan, correct? The back of the Milodon pan is almost where a stock pan is. If you run a stock pan with your setup does the drag/centerlink hit the drain plug when at full turn?
You may be able to cheat with the www.firmfeel.com longer pitman/idler arms. But they may be too long for your headers. Even though when you go to full turn the pitman and idler would come very close (probably hit) to the back side angle of the pan.
