Soaping slicks. Do you have a favorite? #951873
03/16/11 11:21 AM
03/16/11 11:21 AM
Mansfield, Tx
Jacob Pitt Offline OP
Mansfield, Tx
When running slicks without tubes and soaping the inside to help them not leak, do you have a soap that works better than the others? I'm taking the radials off the Challenger and going back to a regular slick, but plan to run them without tubes. So is there a special soap that works best?
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Soaping slicks. Do you have a favorite? [Re: Jacob Pitt] #951874
03/16/11 11:24 AM
03/16/11 11:24 AM
tboomer Offline
tboomer  Offline
I have always used Palmolive! Hey...It worked for Madge!!
Re: Soaping slicks. Do you have a favorite? [Re: Jacob Pitt] #951875
03/16/11 11:28 AM
03/16/11 11:28 AM
Locomotion Offline
Locomotion  Offline
I use to use Dawn and then some of the cheaper brands. It seemed like the cheaper brands tended to "wax-up" more than the name brands. They may have changed the formulation of the name brands over the years so I don't know about them now. Haven't soaped my slicks since going to the Hoosier lightweight radials many years ago.
IHRA has Dallas race photos up!
IHRA Dallas, TX divisional race photos
Re: Soaping slicks. Do you have a favorite? [Re: Locomotion] #951876
03/16/11 11:38 AM
03/16/11 11:38 AM
Re: Soaping slicks. Do you have a favorite? [Re: ] #951877
03/16/11 11:56 AM
03/16/11 11:56 AM
sg66mopar Offline
sg66mopar  Offline
My tire guy has used Dawn dish soap on mine for years. They would just leak enough to lose about 1 or 2 pounds in a week.
Three years ago I started buying from a different tire guy who doesn't use anything. All the tires I've bought from him have lost about 1 pound in a couple months. I pump the tires up to 10 PSI in September and in March or April the tires are still at 5-6.
Re: Soaping slicks. Do you have a favorite? [Re: sg66mopar] #951878
03/16/11 12:30 PM
03/16/11 12:30 PM
New Jersey
Craig Offline
Craig  Offline
New Jersey
I used dish soap when I first got my new Monocoque wheels and next time I changed the slicks the wheels were all pitted inside. Use a real tire lube, they are non-corrosive. I had Ballistol already on hand, and tire lube is one of its uses, so I used that. It works a lot better than soap too. I'm referring to mounting the tire, neither soap nor lube is going to seal a leaky tire/wheel.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Re: Soaping slicks. Do you have a favorite? [Re: Craig] #951879
03/16/11 01:49 PM
03/16/11 01:49 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
The Hoosier dealer told me to use Joy dish soap and Joy only. I have had the tires on my car all winter in the cold garage -20 to -30 below at points and havent had to put air in them all winter! They are starting to look a little low but its been 7 months since I put air in them.
67' charger 499 RB 10.57 at 127
Re: Soaping slicks. Do you have a favorite? [Re: dragram440] #951880
03/16/11 01:56 PM
03/16/11 01:56 PM
Mansfield, Tx
Mansfield, Tx
Thanks for the tips, and thanks for the link Myron!
14x Track Champ
Re: Soaping slicks. Do you have a favorite? [Re: Jacob Pitt] #951881
03/16/11 02:49 PM
03/16/11 02:49 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use Dawn on used tires, maybe I'll try Joy on the next set.I have not had to use soap when buying new tires and mounting them tubeless
Re: Soaping slicks. Do you have a favorite? [Re: Cab_Burge] #951882
03/16/11 05:44 PM
03/16/11 05:44 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Dawn works for me
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Soaping slicks. Do you have a favorite? [Re: W.I.N. Racing] #951883
03/16/11 06:04 PM
03/16/11 06:04 PM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
Dawn works for me
same for me too.
Re: Soaping slicks. Do you have a favorite? [Re: Valiant_Showoff] #951884
03/16/11 06:15 PM
03/16/11 06:15 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Dawn works for me
same for me too.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Soaping slicks. Do you have a favorite? [Re: pittsburghracer] #951885
03/16/11 08:45 PM
03/16/11 08:45 PM
TN
65racer Offline
2009 IHRA World Champion
65racer  Offline
TN
Have had my best results using Dawn,
plus I like the lemony smell.
Plus if you use any of those so called
tire shine sprays, get ready to start
putting air in your tires, that stuff soaks
thru the sidewall, and they will start
leaking, just like you never used anything
to seal them up. AMHIK
Re: Soaping slicks. Do you have a favorite? [Re: 65racer] #951886
03/16/11 09:40 PM
03/16/11 09:40 PM
Nevada
Darter6 Offline
Darter6  Offline
Nevada
Been using Joy for years. FYI "Slime" will destroy aluminum. I lost a set of Centerlines because I wanted to try something different.
Re: Soaping slicks. Do you have a favorite? [Re: Darter6] #951887
03/16/11 09:43 PM
03/16/11 09:43 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I use Oil of Olay to get rid of the wrinkles in the sidewalls.
Floyd Lippencott IV
Re: Soaping slicks. Do you have a favorite? [Re: mr_340] #951888
03/17/11 01:49 AM
03/17/11 01:49 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I use lemon joy.
Re: Soaping slicks. Do you have a favorite? [Re: FastmOp] #951889
03/17/11 02:38 AM
03/17/11 02:38 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
i got real lucky with mine--i did rub the inside with generic $1 Dollar General soap .
Ive had these on the car for at least 2 years and they have never leaked at all. Not even through the brutal cold winters.
hoosier slicks - no tubes on Welds
Re: Soaping slicks. Do you have a favorite? [Re: 493_DART] #951890
03/17/11 05:57 PM
03/17/11 05:57 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Everyone overlooked the main thing. Unless they are new if you do not clean the beads(I clean all of the inside)of the rims good nothing will help them seal. The tire changer unless its you is not going to clean inside the rims.
I guess about now you are thinking what I used to think,they were new rims when I put the last set on.There is no way they have gotten any dirt rubber,any surely they did not scratch them when they mounted them last. I now not only stand there and watch but check everything myself.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
